HBO GO Issues on iPad 2
This is a discussion on HBO GO Issues on iPad 2 within the iPad Help forums, part of the Apple iPad Discussions category; Having trouble getting HBO GO to work on my iPad 2. Worked fine on iphone 4. Downloaded app on iPad 2 but everytime I try ...
Results 1 to 5 of 5
    62418
    Jun 2011
    Cool HBO GO Issues on iPad 2
    Having trouble getting HBO GO to work on my iPad 2. Worked fine on iphone 4. Downloaded app on iPad 2 but everytime I try to sign in I get a pop up message ERROR 30-33. Have deleted and reinstalled multiple times. Still same error. Trying to figure out if this is a problem with iPad 2, perhaps settings, or some type of login issue. Can currently access HBO GO on computer and iphone just not iPad 2. Anyone else have this problem?
    39859
    California
    I'm not having the same problem but my app isn't working either. I can run the app on my iPhone 3, but on my iPad 2 when I start watching a show it locks up and the show freezes or the app just shuts down. My cable and Internet provider is comcast, maybe that has something to do with it? Or does HBO Go not run on the iPad 2
    260184
    Nov 2012
    New york
    Hbo go does not work on my iPad3. It did when I had comcast. Now I have direct tv. Keep getting error message http proxy not
    Supported and to delete from wifi settings. Whatever that means. Called apple support they said it was a provider problem called
    Provider direct tv they had no idea what I was talking about. Works on my desktop just fine.
    279235
    Feb 2013
    PA
    Quote Originally Posted by Mz Bize View Post
    I'm having the same problem with comcast on my iPad 2. Same error message you are getting. My iPhone works fine with it. The app won't play at all on my iPad. It had been a while since I used it, but it worked fine before the update that is supposed to allow streaming with AirPlay.
    279235
    Feb 2013
    PA
    Emailed comcast about this problem. They said to go into the wifi settings for my iPad and click on forget this network. The arrow next to the wifi network you are using. I have to tell you I had zero confidence that this would work. Once I did that, I re-entered my network password and now it works. I hope this works for you.
    Here's a copy of the email sent to me:
    Thank you for your email. We suggest turning Wi-Fi Networks off or try removing Wi-Fi Networks you have connected to previously. Since known networks will be joined automatically it is possible that one of your Wi-Fi Networks could have a proxy turned on by default. To remove a network, click on the arrow to the right of the name and choose the option to “Forget this Network”.
    Good luck.
  1. iPad Sync Issues
    By Pszilard in forum iPad Help
    Last Post: 12-27-2010, 01:01 AM
  2. Issues with SSH for iPad
    By rotaz in forum iPad Hacking
    Last Post: 10-27-2010, 09:32 PM
  3. Anyone having issues SSH to your iPad 3G?
    Last Post: 10-24-2010, 06:34 PM
  4. 2nd hand ipad issues
    By whitdavey in forum iPad Help
    Last Post: 09-26-2010, 04:30 PM
  5. How to Fix the iPad's Wi-Fi Issues
    By cimousa in forum iPad Help
    Last Post: 04-28-2010, 12:09 PM
hbo go app not working
hbo go crashes on ipad
hbo go ipad help
hbo go ipad problems
hbo go not working on ipad
hbo go wont load on ipad
unable to watch hbo on ipad http proxy
why doesn'tmy hbogo workon my ipad2
