Deleting a Calendar Entry
This is a discussion on Deleting a Calendar Entry within the iPad Help forums, part of the Apple iPad Discussions category; This is SO frustrating! A buddy sent an appointment from his iPhone to my email account, but he set up the appointment incorrectly. I did ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Like Tree2Likes
Thread: Deleting a Calendar Entry
    62265
    Jun 2011
    San Francisco
    Deleting an Appointment - or Not!
    This is SO frustrating! A buddy sent an appointment from his iPhone to my email account, but he set up the appointment incorrectly. I did not know this when I accepted the appointment, but now, I want to delete the one he sent and replace it with my own, but when I open it in the Calendar, I get Event Details with no option to delete.
    No, I am not syncing to any other calendar, and yes, I did ask him to delete it (as he's using mobileme). Yes, I have powered off and back on. I'm leery to do a reset, but I have backed up the iPad using iTunes. Now, if you click around in the original email, you get, "This event has been canceled by its owner."
    I've searched around and found nothing, and I'm about to go finish ripping my hair out. Any help would be greatly appreciated!
    37823
    479 times
    Cranbrook, Kent, UK
    15,236
    I don't know the answer, but have you tried swiping your finger left to right across the event?
    37823
    479 times
    Cranbrook, Kent, UK
    15,236
    Ok I just tried, tap the event to get the details pane open then swipe your finger left to right across the details pane, I did this and got the delete option.........the only thing is, mine is not an invited event so until you try I can't be certain that it will work for you......let us know how you get on?
    116 times
    15,249
    So, if you touch the event in Calendar, it opens up - is there then an Edit button? If so, I'm guessing you're telling us that, when the edit window opens up there's no big 'Delete Event' button at the bottom of the edit window?
    All the events in my calendar have been created locally, so I don't have any appointments etc that have been received from an email. I know - from other cases of other iPad apps - that the iPad often doesn't allow you to delete items - for example photos - that weren't created locally so maybe this is another example of this.
    Let me know what happens when you open up the event - i.e. do you even see an 'Edit' button and, if so, confirm (of course!) that there's no big 'Delete Event' button. If that's the case, I'll try sending myself some invitations and see if I can subsequently delete them!!
    Good Luck...
    12657
    4 times
    Aug 2010
    Area DM51
    669
    I can confirm that these "invitations" can be a PITA, on a PC as well as an iPad. I no longer accept them - they can be difficult to edit or get rid of. It seems quite random. I haven't really bothered with trying to find a solution, as of course they gradually disappear into the past, and by declining them the problem no longer bothers me.
    There's one exception to this - for some inexplicable reason, my calendar contains an annually recurring note of the birthday of someone I know only slightly, and I honestly have no idea how it got there. Every year it reappears, and I try to delete it each time, but it won't go away. Just as well it's not a female, or Mrs. DM51 might have some awkward questions for me, lol.
    I'm pretty sure it's a software/incompatibility problem, but it would be useful to hear from other members on this. In the meantime, I would recommend the OP (and any others affected) to decline/reject these calendar "invitations" and enter the information manually.
    37823
    479 times
    Cranbrook, Kent, UK
    15,236
    The op posted this question twice, this is my response in the other thread.....it may or may not work!
    12657
    4 times
    Aug 2010
    Area DM51
    669
    Thanks, Gabriel - I've merged the 2 threads.
    104515
    Sep 2011
    Costa Rica
    I have a similar behavior when I receive a mail containing an appointment, a *.ics file as attachment and tap on it. It adds a new task in calendar that I cannot edit. Where it should be the "Edit" button I have a "Details" button, so I can't do nothing with the task. Usually, this appointment comes from an exchange server, if that helps.
    Some help would be appreciated for me too.
    123635
    2 times
    Nov 2011
    I have tried the swipe on new events created on my iPad and do not get the delete option.
    KarenK01 and cflesher like this.
    49442
    UK
    123
    Quote Originally Posted by DM51
    Is the birthday also listed in your contacts under that person's name? If so, try removing that birthday information from your contact list.
    Not sure if that will work, but can't hurt to try.
  1. Help - Need a data entry app for an expo
    By kjreif in forum iPad General Discussions
    Last Post: 01-25-2012, 10:08 AM
  2. How do I copy a calendar entry?
    By Slimbinki in forum New Member Introductions - Site Assistance
    Last Post: 03-20-2011, 09:29 PM
  3. Deleting Calendar Appointments
    By slothead in forum iPad Help
    Last Post: 02-26-2011, 07:10 AM
  4. ipad calendar entry not updated in Outlook
    By slowkitty in forum iPad Help
    Last Post: 01-19-2011, 08:05 PM
  5. Replies: 0
    Last Post: 10-14-2010, 04:33 PM
delete calendar event iphone
delete ipad calendar entry
how to delete an event on ipad calendar
how to delete an event on iphone calendar
how to delete calendar events on ipad
how to delete calendar events on iphone
how to delete event on ipad calendar
how to delete event on iphone calendar
how to delete events on ipad calendar
how to delete events on iphone calendar
ipad calendar delete event
iphone delete calendar event
Tags for this Thread
