iPad2: no sound when typing, email arrives/sent, etc
This is a discussion on iPad2: no sound when typing, email arrives/sent, etc within the iPad Help forums, part of the Apple iPad Discussions category; I'm an idiot! I continued my search and just realized that I accidentally turned the mute button on when I slipped my iPad into my ...
Results 1 to 10 of 12
    58222
    May 2011
    hawaii
    29
    I'm an idiot! I continued my search and just realized that I accidentally turned the mute button on when I slipped my iPad into my thin SFBag sleeve! Ugh. I'm embarrassed! I hope this post might help someone else as dense as me!
    Original post below:
    It's really weird: my iPad 2 is working fine but just late last night, I noticed that there's no sound when I receive/send mail, wake it from it's sleep, type, etc.
    When I play a movie, I can hear the sound perfectly well.
    I hope I'm just doing something really stupid and won't have to get a replacement.
    PS: yes, I went into settings and I think I've got everything turned ON. Also, I powered down completely but I've still got this problem.
    I hope someoneout there will printout a simple solution.
    Thanks!
    7489
    126 times
    Jun 2010
    Sacramento, California
    14,962
    Try this: Hold down the power button and the home button at the same time. Wait until you see the Apple logo. Let it reboot.
    Let us know how that worked for you! Or if not.
    Marie ~
    Forum Rules. Please Read.
    appleforums.net
    63928
    Jun 2011
    Same problem here with iPad 2! Sound of key clicks/slider click gone. iPod works fine, vids fine, settings are fine. All games I've tried have no sound. I've deleted all recently added apps & games. Did the 2 key reset/reboot several times.
    UPDATE: problem solved! While on desktop double click home button and go to far left to see if "speaker" button has line thru it -- Done.
    29345
    49 times
    Penarth, Wales, UK
    1,935
    yes, turning the sound up/down via the volume rocker isnt the only fix. you must also double click the home button, swipe to the left, then turn the main vol up there too.
    58222
    May 2011
    hawaii
    29
    i'm glad you weren't as dense as i was! and glad to hear that your solution was an easy one. hopefully, our posts will help someone who faces a similar problem in the future.
    61788
    Jun 2011
    USA
    32
    Quote Originally Posted by sjleworthy
    What is the "speaker button"? When I double click the home button on my iPad2, I get the bottom window opening, which lets me close open apps, but I don't see anything like a speaker button. The only thing I can imagine is swiping to the left while on the desktop where I see a volume control, but mine looks like it's set at mid-range, yet I no longer get the click when I close the smart cover, nor the chime when I plug in power (and I'm missing those sounds). Pls help.
    116 times
    15,249
    Quote Originally Posted by DeniseB View Post
    Do you have the Mute control activated? On iOS 4.3 and above it's possible to assign the Mute control to either the small slider switch near the volume control or to a 'soft' control that's in the multi-task bar.
    Try sliding the switch next to the volume control. One of two things will happen - either this will lock the orientation of the screen (you'll see a lock symbol appear in the top right hand side of the iPad screen) and, if you rotate your iPad the screen orientation will no longer change or it will mute/un-mute system sounds.
    If it locks/unlocks the screen orientation, then the mute control has been set to be controlled by the soft button that's in the multi-task bar when you 'flick' the multi-task bar right. You can change the assignment between the two locations - switch or soft control - in the iPad 'Settings' menu.
    Dav
    Dav is offline
    5524
    May 2010
    58
    Glad you got the isssue sorted out, that is easily down when removing or Putting iPad into tight sleeve.
    58222
    May 2011
    hawaii
    29
    Quote Originally Posted by Dav View Post
    yeah, it was such a simple solution; i was just unaware of the switch being there!
    61788
    Jun 2011
    USA
    32
    That was it! Thank you. I apparently had the side swnitch set to mute control, and it was 'on'.
    Thank you!
  1. Alert sound of my ipad2
    By doinks in forum iPad General Discussions
    Last Post: 04-24-2011, 09:48 AM
  2. ipad2 and surround sound
    By alliebuck in forum iPad 2 Forum
    Last Post: 04-19-2011, 06:57 AM
  3. Replies: 1
    Last Post: 04-10-2011, 09:41 AM
  4. Wi-Fi only w/o 3G iPad2 ... better sound
    By madhatter61 in forum iPad 2 Forum
    Last Post: 03-18-2011, 09:00 AM
  5. Replies: 19
    Last Post: 03-14-2011, 10:16 PM
ipad email no sound
ipad email sound not working
ipad typing noise how to turn pn
my ipad makes no sound when typing
no sound in i pad when i send mail
no sound on ipad when receiving email
no sound when i get new e-mail ipad
no sound when i type on ipad
no sound when sending mail ipad
no sound when typing on ipad
no typing sound on ipad
why isnt my ipad making a sound when i fire off an email or receive one
Tags for this Thread
