Public Wifi Issues
This is a discussion on Public Wifi Issues within the iPad Help forums, part of the Apple iPad Discussions category; I have a 32 g WIFI IPAD 2, I am able to connect via Wifi at home just fine. I am even able to connect ...
Results 1 to 5 of 5
    54818
    May 2011
    17
    Public Wifi Issues
    I have a 32 g WIFI IPAD 2, I am able to connect via Wifi at home just fine. I am even able to connect on someone else's wifi in my building even though it shows as two bars as signal it seems to be just fine as well. But if I am in public like a park or public space where they have wifi I have so much trouble connecting even when it shows it has 3 bars? And when it does connect the connection can be really slow, am I doing something wrong is this a known issue, do I have to be really close to the access point or is there a lag because so many people are using the connection at once?
    29345
    49 times
    Penarth, Wales, UK
    1,935
    Poor public wifi issues isn't your fault, it's theirs.
    60724
    May 2011
    UK
    9
    Smile
    While sjleworthy makes a fair point. There are other factors which could obstruct the strength of the signal.
    For example if the wifi is near civic buildings in a city centre, the type of stone they were constructed with can block or interfere with or obstruct the signal.
    So where ever you chose to sit down and use public wifi the strength of the signal will always be affected by whatever material it encounters in its path to where you are seated.
    The technology was only developed for short distances so even in a public place you will have to be located fairly near the source of the signal to get a good reception.
    39199
    2 times
    173
    Also public WiFi gets hammered with bandwidth, if you're in a place that has a ton of people sharing the WiFi, it's gonna slow down. Probably not your iPad, but the amount of people sharing.
    7684
    Jun 2010
    112
    Quote Originally Posted by chevyguy View Post
    Same thing can happen in a coffee shop setting if lot of other customers are there utilizing the free wifi. It's all about sharing band width in the wifi world.
  1. Wifi Issue at Public Hot Spots
    By tibob in forum iPad General Discussions
    Last Post: 05-12-2011, 09:38 PM
  2. Wifi at Toronto Public Library
    By clrk9000 in forum iPad General Discussions
    Last Post: 05-05-2011, 11:32 PM
  3. Public WiFi Hotspots
    By Tom P. in forum iPad 2 Forum
    Last Post: 04-10-2011, 10:09 AM
  4. Public WiFi security
    By jimfastcar in forum iPad Help
    Last Post: 12-14-2010, 04:50 PM
  5. Useing the Wifi in public places..
    By henry2 in forum iPad General Discussions
    Last Post: 04-06-2010, 04:08 PM
how to connect ipad to secure public wifi
ipad 2 not connecting to public wifi
ipad and public wifi
ipad problem connecting to wifi public
ipad public wifi
ipad will not connect to public wifi
public hotspots for wifi i pad
public wifi slow
public wifi slow on ipad2
slow public wifi
why is public wifi slow
why is public wifi so slow
