Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    61261
    Jun 2011
    5
    Grouping apps into folders problem
    Hi I am trying to tidy up my home screen on my iPad by grouping the apps into folders. Now on my iPhone those is easy but when I make the apps wobble and try to put one on top of the other the other one just moves out of the way.
    What am I doing wrong please?
    18578
    10 times
    Oct 2010
    Virginia, usa
    608
    As you approach the target slow down your finger and very gently move it on top of the other app, then release. It can be tricky at times. TIP, to move from page to page, drag app to the task bar, then page to the target page and drag the app out of the task bar to where you want it to go. Much easier that way.
    Good Luck
    Pocobear
    iPad Junkie!
    51269
    May 2011
    120
    You need to make sure you drop it squarely on top. In other words, better aim. I am not tweaking you, I have had the same thing happen.
    You know that you can also do this after syncing, in the Apps tab on the iPad in iTunes? You then click 'apply' to re-sync the changes. I find it easier to do on the computer than on the iPad but YMMV.
    622 times
    Dayton, WA
    13,310
    Is it an iPad1? Then what iOS version is your iPad running? It has to be at least 4.2.x to create folders. Go into Settings >> General >> About and check your version number to be sure.
    61261
    Jun 2011
    5
    Twerpoet yes it is an iPad 1! I was reading through the forum and found out that because I bought my iPad in september 2010 I only have the old ios version as the new one came out in November.
    I have read a bit about Jailbreak but is there any other way to get the 4.2 as I am not very good at the technical stuff and would worry I'll lose everything on my iPad?
    116 times
    15,249
    Quote Originally Posted by Todd74 View Post
    The current version of iOS is 4.3.3 but it's expected that iOS 5 will be released on this coming Monday. There's absolutely no need to jail break, so can simply move up to 4.3.3 today or 5 on Monday using iTunes..
    Banned
    48444
    Wales
    667
    You don't need to Jailbreak to get the latest os, just plug your iPad into your PC and when prompted, download and install the new update ( latest version is 4.3.3) the whole process takes about 15 minutes, and you won't lose data, as iTunes will back up your stuff prior to updating.
    You will probably find that a lot of you apps need updating too, this can be done too, but I suggest you untick the " sync automatically " box, and manually select what you want to sync by ticking the relevant boxes in each section. Apps, Music, photos etc.
    Once you've done this, you will be able to create folders on your home-screen, just drag one app onto another, and off you go! Best to give it some thought as to what goes where though! I let a friend play with mine, and she put all sorts of things in the wrong place....had to do it all again myself!
    Post back and let us know how you get on!
    61261
    Jun 2011
    5
    Thank you so much for all your help.
    I will wait until Monday and then attempt to upgrade to the 5 and will let you know how I get on.
    Thank you once again
    622 times
    Dayton, WA
    13,310
    While iOS 5 will be announced Monday it is unlikely that it will be released immediately. Still, if you are in no hurry I suppose it won't hurt to wait, just in case.
    Banned
    48444
    Wales
    667
    But It Works With 4.3.3
    Unless I have an update no one else does. also works in Pages now REALLY useful Now where is that young singer who thought putting ALL my apps in one folder was a good idea? I know, I shall be seeing her tommorow
    "But it looks tidy that way"
    Yeah, Right!
  1. Disappearing Folders for Apps
    By iPadMomma in forum iPad Help
    Last Post: 07-26-2011, 02:45 AM
  2. Folders for apps
    By Laurieth in forum iPad General Discussions
    Last Post: 04-10-2011, 10:55 PM
  3. Combining apps into folders problem
    By zoron in forum iPad Help
    Last Post: 03-13-2011, 06:06 PM
  4. Grouping Objects in Keynote?
    By Greggles in forum iWork Forum
    Last Post: 02-20-2011, 08:27 AM
  5. Contact grouping apps
    By paulyeo11 in forum iPad Apps
    Last Post: 07-30-2010, 10:54 AM
combine apps on ipad
combining apps on ipad
group apps on ipad 1
grouping apps on ipad
how do you combine apps on ipad
how to combine apps on ipad
how to combine apps on ipad 2
how to group apps on ipad 1
ipad 2 combine apps
one app won't move into folder ipad
why won't some apps go in groups with others?
why won't some apps group
