My ipad backup is less than actually on ipad! help
This is a discussion on My ipad backup is less than actually on ipad! help within the iPad Help forums, part of the Apple iPad Discussions category; WHen i connect the ipad to itunes..i have 2.7 gb of apps and rest other..i dont know whether videos and music also gets backed up..but ...
WHen i connect the ipad to itunes..i have 2.7 gb of apps and rest other..i dont know whether videos and music also gets backed up..but anyway..
when i used to do backups before it used to be around 10 gb which was exactly what i had on ipad..
now i have deleted some videos and as i said i have said before -2.7gb of apps..but when i backup manually it backs up the ipad to 628mb..i checked the backup folder in -- C:\Users\(your username)\App Data\Roaming\Apple Computer\Mobile Backups
and it shows 628 mb only..how can this be when apps are 2.7 gb? HELP? why is it backing up less?
Sent from my White iPad 2 in India
06-01-2011 11:32 AM
anyone??
Banned
Originally Posted by
iRuthlessPad
Sounds as if you have left some of the sync tick boxes in iTunes blank.
Open iTunes and go check that the automatically sync button is unticked ( this prevents iTunes from syncing things you may not want)
Go to the app tab, and make sure the " automatically sync apps" box is ticked.
Go to music tab, and make sure all the folders you want music from are ticked.
Go to the photo tab and do the same as above.
Connect your iPad and sync it again.
Tip: if you wish to remove items from your iPad untick the folder or folders you wish to remove, then sync again. This will not delete apps music films or photos from iTunes, just from your iPad.
Hope this gets you going
no didnt help..still makes backup of 628 mb only
Your backup does not contain all of the stuff that is already in iTunes, such as your apps, music, videos, etc. So it's absolutely fine that your backup size is less than all the stuff you have on your iPad.
When you fully restore an iPad you restore the backup and re-sync all your media / apps back onto the device. Think of your backup like all of the stuff which is not available from the iTunes library!
ok..so syncing also saves the apps to pc?
Yes by default syncing transfers apps and media both to and from your iPad (although it does depend on how you have set up iTunes in relation to your iPad - you have control over this completely).
When you purchase / download things from the iTunes / App stores on your iPad they get transferred to your PC the next time you sync, and vice-versa. When you sync it also creates a backup.
Your apps aren't even really physically saved on your PC - there'e a record of what you have, but it's held in your iTunes a/c. So if you change your PC/laptop for a new one, all you have to do is log in to your iTunes a/c and it will all still be there.
DM51
I get what you mean DM51, but they are also physically there in your iTunes folder structure... Have a look and see...
...\iTunes\iTunes Music\Mobile Applications\
Those are all your personally signed apps for your iTunes account download from either the iTunes store on your PC or synced across from your iPad.
Don't be overly concerned about the backup file size. It does not contain everything that is on your iPad. It does not contain any of your media; stuff that is stored in the iTunes library on the computer. That is saved and restored via a sync, not a backup and restore.
Here is Apple's tech page on backups. If you expand About Syncing and Backups, and then expand Information iTunes will backup, you can see a (probably not complete) list of what actually goes into the backup file.
iPad: About backups
- You may not post replies
- You may not edit your posts
Forum Rules
By DUTCH VanAtlanta in forum iPad General Discussions
Last Post: 08-05-2012, 01:56 PM
By sisyfos12 in forum iPad Help
Last Post: 03-10-2011, 11:07 PM
By liamsutton6 in forum New Member Introductions - Site Assistance
Last Post: 02-26-2011, 03:43 PM
By mariojesman in forum iPad General Discussions
Last Post: 04-26-2010, 08:15 AM
backup iphone size lower than
delete my ipad backup folder
ipad backup everything
ipad backup file size
ipad backup size
ipad backup small
iphone backup smaller
ipod backup file small
itunes backup size
itunes backup smaller than
what does an ipad backup contain
why is itunes backup smaller
