Help needed for android converter...
This is a discussion on Help needed for android converter... within the iPad Help forums, part of the Apple iPad Discussions category; Never owned apple products till ipad2. Qns: How to sync 2 pcs w/o erasing data. Eg, photos n music. how to delete photos after syncing ...
Results 1 to 9 of 9
    60991
    May 2011
    Singapore
    6
    Unhappy Help needed for android converter...
    Qns:
    how to delete photos after syncing from pc in iPad.
    Already did home sharing for 2pcs. But still have pop up to replace photos when I try to sync.
    Thanks in advance...
    60991
    May 2011
    Singapore
    6
    Quote Originally Posted by iPad2_idiot View Post
    Qns:
    Anyone?
    116 times
    15,249
    I can answer one of your questions. If you transfer photos from your PC to your iPad using iTunes then those photos cannot be deleted on the iPad itself. Rather, you have to delete them from the PC first of all and then resynch. Only photos that are in the iPad's Photos app that have not been imported using iTunes - such as an email attachment, for example - can be deleted on the iPad.
    11919
    9 times
    Aug 2010
    Virginia, USA
    718
    Clarify your question for us, please
    You asked how do you synchronize one PC with another. Did you mean that literally or did you mean how do you synchronize an iPad with a PC?
    How do you delete photos from what? Tim addresses the difference in dealing with photos downloaded directly to the iPad via camera connection or via e-mail - delete directly on the iPad. That is different from the process of deleting photos imported from iTunes as he points out.
    Music is handled differently.
    You may want to refer to Apple's instructions.
    Apple - iTunes - Tutorials - Learn about all things iTunes.
    If my Irish Wolfhound doesn't like you neither will I.
    2012 13" MBA, 2011 11" MBA, 2010 15" MBP, 2 iPad3s, 1 iPad Mini, iPhone 4S and iPhone 5. A bunch of iPods and an Apple TV.
    60991
    May 2011
    Singapore
    6
    Thks guys, I used the cable and sync my iPad to my office pc. itunes popped up. I have photos in my office pc which I wanna transfer to iPad. But when I click the photos part, select the folder and click apply, iTunes prompt me that it will replace all photos in iPad except camera roll.
    I accepted. Then realized that all photos from my home pc were gone.
    I clicked home sharing for both office n home pc already. I thought we can add new stuffs without erasing existing data...
    60991
    May 2011
    Singapore
    6
    Anyone? Pls advice... Checked manual, no answer that I can see...
    iPad Enthusiast!
    54460
    May 2011
    NYC
    46
    Welcome to the wonderful world of iTunes. The only way I've figured out how to do this is get all the photos on the work PC to the home PC via USB, Dropbox etc and then sync iPad. The network sharing means you can read files between PCa but not sync (I think.) I already have a media server running so iTunes homesharing felt useless to me.
    As far as I know...once you plug it into one PC it will overwrite the files from the other. There's no way to just add more files.
    You really need to start uploading your stuff to Dropbox or Goodreader since iPad doesn't have anyway to manage the file system.
    Sent from my Xoom using Tapatalk
    60991
    May 2011
    Singapore
    6
    thank you for the explanation. I do have dropbox on my android phone. i didn't know how to use it therefore I haven't actually started.
    perhaps i'll start using dropbox and transferring all my photos to home pc then..
    another silly qn: do I have to use the same folders? or can I just add another folder to the sync process?
    iPad Addict
    37720
    6 times
    Colonial Heights,Va
    1,395
    What I did was create a folder called "Marks Ipad" in my desktop and I copy pictures and folders into it and sync Marks Ipad only. I can change photos in the folder and when I sync it changes them on my Ipad.
    Dropbox; go to the website, sign in, click upload, choose a file, upload it, done .
    On your phone or Ipad open the app , tap dropbox, tap the folder you uploaded the photo to, tap the photo, on the Ipad upper right corner is a box with an arrow, tap it to save the photo. On your phone do the same except press/hold the photo until options come up, choose download.
    PM me if you need help uploading from your phone or Ipad but it's just as easy.
    With photos you save from dropbox you can delete them without iTunes,a very nice perk
    Support Our Troops!!
    This post was Tapatalk approved. Sent from an Incredible phone
convert android pictures to ipad picture
delete data converter
how do you delete the data converter on an android phone.
how to delete data converter on the an android
how to delete the data converter
how to get pictures from android phone to ipad
how to transfer photos from android to ipad
import android image into ipad
