iPad backlight not working
This is a discussion on iPad backlight not working within the iPad Help forums, part of the Apple iPad Discussions category; Hi, my iPad's backlight has completely stopped working. The screen is barely visible, I can almost make things out when I shine a light on ...
Results 1 to 3 of 3
    60900
    May 2011
    Hi, my iPad's backlight has completely stopped working. The screen is barely visible, I can almost make things out when I shine a light on the screen so I know it's still sort of working.
    Any advice would be greatly appreciated
    579 times
    Dayton, WA
    13,189
    Things to try.
    Hold down the power and home button until the Apple logo appears. Ignore the power off slider if it appears. Let the device reboot.
    Go into Settings > Brightness & Wallpaper, turn off Auto-Brightness and up the slider.
    And if neither of these works, and I don't really expect them too, call Apple Support. Your iPad is broke. If it's under warrantee (less than a year old or has Apple Care) they should replace it for free.
    You might want to connect it to iTunes, Transfer Purchases, Backup, and Sync before taking it to the Apple Store, or sending it in. It will make setting up your new one easier.
    Last edited by twerppoet; 05-31-2011 at 06:25 PM. Reason: fixed you're vs your mistake, just because
    60900
    May 2011
    Thanks a million for your help, tried all of that but to no avail. I'll ring Apple support in the morning, thanks again!
  1. Replies: 221
    Last Post: 08-12-2011, 12:39 AM
  2. Replies: 0
    Last Post: 05-25-2011, 10:25 AM
  3. Replies: 8
    Last Post: 04-20-2011, 08:10 PM
  4. Replies: 4
    Last Post: 04-18-2011, 08:09 PM
  5. Replies: 0
    Last Post: 12-08-2010, 10:13 AM
backlight on ipad 2 not working
backlight on ipad not working
ipad 1 backlight not working
ipad 2 backlight not working
ipad 2 display light not working
ipad 2 no backlight
ipad backlight
ipad backlight not working
ipad backlight problem
ipad no backlight
ipad screen barely visible
ipad2 backlight not working
