Problems with Photos
This is a discussion on Problems with Photos within the iPad Help forums, part of the Apple iPad Discussions category; Hello iam new to this site I have a problems with downloading photos from e-mail to photos when i save image i go to the ...
Results 1 to 6 of 6
    60703
    May 2011
    Uk
    Hello iam new to this site I have a problems with downloading photos from e-mail to photos when i save image i go to the photos album it come up with a grey box with jpg written on it the problem has only just started occurring can anybody help me would be much appreciated
    116 times
    15,249
    60703
    May 2011
    Uk
    Thanks for replying Tim I have tried your suggestions but still having the same problem any more suggestions would much appreciated
    580 times
    Dayton, WA
    13,191
    Gray box? Hmm, a gray line surrounding the file name?
    If so, and the line is dashed, tap on the file and let it download. Once the line is solid tap and hold until the popup menu appears. Choose Save, and it should go to the Photo's app, Saved Pictures album.
    Or I'm out in left field and need more info to make a better guess.
    60703
    May 2011
    Uk
    The grey box appears when I have downloaded from my e-mall into photo album when in the album a grey box appears with jpg on it and it does nothing
    580 times
    Dayton, WA
    13,191
    Quote Originally Posted by liamwolves
    A restart will fix this most of the time. Hold down the power button until the power off slider appears. Slide it off. When the iPad finishes shutting down, hold down the power button again until the Apple logo appears.
    Try it more than once. We recently had another thread with the same problem. We never pinpointed the cause, but after one of several restarts while trouble shooting, the picture just started working.
  1. Itunes and Syncing Photos Problems
    By HarveyA in forum iPad Help
    Last Post: 10-15-2011, 04:12 AM
  2. Problems syncing photos to my iPad
    By rabogardus in forum iPad Help
    Last Post: 03-31-2011, 08:06 PM
  3. problems with downloading photos
    By treeguy in forum iPad General Discussions
    Last Post: 03-15-2011, 02:45 AM
  4. Problems with Photos & Keynote
    By toothdoctor in forum iPad General Discussions
    Last Post: 01-22-2011, 02:45 PM
  5. Problems with photos
    By Kellykelly in forum iPad Help
    Last Post: 11-29-2010, 03:44 PM
how come my iphone pictures are grey and show a jpg
ipad appears blank images with the jpg
ipad photos grey
ipad problems photo
ipad save to album
iphone 5 picture messages is just a grey screen that says jpeg image
iphone grey box jpg
iphone photos blank jpg
iphone photos show up as grey
jgp on my iphone album
jpg file downloaded is appearing blank on ipad
photos ipad problems
