The low memory messages call for me to shut down the iPad. I found the on/off switch, but where is the home button.
Thanks William dairy
This is a discussion on Having low memory messages on my ipad2 within the iPad Help forums, part of the Apple iPad Discussions category; The low memory messages call for me to shut down the iPad. I found the on/off switch, but where is the home button. Thanks William ...
The home button is the one in the bottom of the screen in the middle. Its the round button.
iPad 2 64GB 3G Black,
iPad 1 64GB 3G,
iPhone 4 32GB Black,
iPod 3rd Gen. 32 GB White.
Get the XSysInfo app. It not only displays how your memory is currently being consumed by various processes, it also has two levels of memory cleansing, normal and "deep", which allows your device to reclaim any unused RAM.
32GB WiFi
To iPad master-
How do get and where do you find the app that you suggested - SXysinpo I checked the app store with no success.
Regards
Buzzy23
shows you where your home button is.
If my Irish Wolfhound doesn't like you neither will I.
2012 13" MBA, 2011 11" MBA, 2010 15" MBP, 2 iPad3s, 1 iPad Mini, iPhone 4S and iPhone 5. A bunch of iPods and an Apple TV.
The app is XSySInfo and it is in the App Store. Check your spelling.Originally Posted by buzzy23
32GB WiFi
I also bought the app thanks for the information!Originally Posted by sjleworthy
