Need help "Paralyzed IPAD Screen)
This is a discussion on Need help "Paralyzed IPAD Screen) within the iPad Help forums, part of the Apple iPad Discussions category; I have a problem with my ipad. (Ipad 1 32 GB Wi-Fi). 4 months ago my IPAD got an impact from its screen. The LCD ...
Results 1 to 10 of 10
    60401
    May 2011
    I have a problem with my ipad. (Ipad 1 32 GB Wi-Fi). 4 months ago my IPAD got an impact from its screen. The LCD screen broke. I changed the LCD screen completely with the digitilizer.
    However, after that a part of the screen is paralysis. I changed the screen 3 times but same failure occurs again. Position of the paralysis part is: IPAD is staying vertical (hoome button below). Imagine that you draw a imaginary line in the middle of the vertical IPAD from left to right. Approx. 1 cm under of this imaginary line. This is where the paralysis part start (height: 1 cm./ wide: left to tight).
    I talked with a service they can't find any solution. If you saw any failure like this, Do you have any idea which part is affacted in the failure?
    7489
    126 times
    Jun 2010
    Sacramento, California
    14,962
    Quote Originally Posted by tunap1980 View Post
    An impact from it's screen? Something hit the screen? I am not understanding what you mean you "changed the LCD screen with a digitilizer?"
    Perhaps someone else can chime in...
    Marie ~
    Forum Rules. Please Read.
    appleforums.net
    59342
    May 2011
    96
    Quote Originally Posted by SweetPoison
    Yep, and replacement lcd screen, diy by the sounds of things
    If several screens have been tried, then it sounds like something else is also broken or you could just be unlucky
    60401
    May 2011
    Yep, something hit the screen and it is broken. After i changed the screen(digitilizer + LCD) the failure that defined above is occur. I changed the screen to check is the screen have a failure. The new screen gave the same failure again.
    59342
    May 2011
    96
    If you turn the ipad 90/180 degrees, is the part that does not respond in the same place?
    If it is in the same place, then i'd hazard a guess that something else was damaged between the screen and graphics chip, if not then i've no idea
    7489
    126 times
    Jun 2010
    14,962
    Quote Originally Posted by HedgeHogLuvva View Post
    Thanks! And thanks for assisting this member.
    Marie ~
    appleforums.net
    60401
    May 2011
    @HedgeHogLuvva: yes, if turn the ipad 90/180 degrees, the part that does not respond in the same place.
    59342
    May 2011
    96
    Sounds like another component was damaged, but before you go buying more replacement bits, try holding down the home button and power button until you see the apple logo, worth a try.
    I've not seen under the screen of an ipad, but i'd guess that there is a cable that connects the screen to the mainboard, check that cable for damage, if there isn't a cable or there is no damage to the cable, also look for damage/scratch on the mainboard, one of the lines from the screen to the graphics chip could be cut, a bit of solder might fix it, otherwise then it looks like a new mainboard, and i'd guess it'll be almost the price of a new ipad...
    60401
    May 2011
    thanx. Will check the cable.
    59342
    May 2011
    96
    No probs and good luck.
    If everything is ok, you could look for damaged ipads where the damage is just outside, or just the screen for example, and build a working ipad out of the 2 non working ipads
  1. Original Ipad "TV Connected" screen problem
    By galzamar in forum iPad Hacking
    Last Post: 05-06-2011, 08:36 AM
  2. Replies: 0
    Last Post: 04-15-2011, 03:17 PM
  3. IPAD 3G 64GB - Locked @ "Connect to Itunes" screen
    By yaponchik in forum iPad Help
    Last Post: 09-15-2010, 09:47 AM
  4. My iPad went "Blue Screen" and...
    By aaron.tan.munloong in forum iPad Help
    Last Post: 08-14-2010, 08:38 AM
  5. Safari stuck on "Apple-Legal-iTunes" screen
    By iBean in forum iPad Help
    Last Post: 06-09-2010, 06:56 PM
broken screen and touch screen problems
fix paralyzed ipods
how can i paralyze ipad screen
how do you fix half of a paralyzed ipod touch screen
how do you fix half of a parolyzed ipod touch screen?
how to fix a paralyzed ipod touch
how to fix ipad screen problem
ipad 1 screen problems
ipad 1 vertical lines fix
ipad vertical lines
ipad1 touch failure
repair paralysed ipod screen
