I want my ipad2 to connect to internet through my pc which runs on LAN at workplace. How do i set it up? Help!!! Please!!! thanks
This is a discussion on Connect ipad with pc - wireless or wifi within the iPad Help forums, part of the Apple iPad Discussions category; I want my ipad2 to connect to internet through my pc which runs on LAN at workplace. How do i set it up? Help!!! Please!!! ...
If your PC at work has WiFi then you can set up a WiFi hotspot
Turn Your Windows 7 PC Into a Wireless Hotspot
If it doesn't have WiFi, then you might need to purchase a WiFi dongle. The iPad cannot be connected via a cable (Ethernet) connection to the Internet.
Thanks, Tim. I am well repaid for the other thread.
I've been doing the same thing on the iMac, and I knew there had to be a way to do it in Windows. I just couldn't find the right combination of settings on the netbook. Windows and I are not the best of friends.
I felt kind of seedy telling people I could only help them with this problem if they had a Mac.
But if I have XP, then is there way to connect iPad via USB cable to my pc and access Internet?
No. You can not get internet to the iPad by any method other than wi-fi. It isn't supported in the software (iOS), regardless of what hardware is present.
If you XP machine is hardwired into the internet (a cable) and has a wi-fi radio as well, then you might be able to use your computer like a wi-fi router; but you can't both get and server internet through wi-fi with the same computer. The hardware doesn't support it, let alone the software.
Create an Instant Wireless Hotspot Using Your Connected Windows XP Notebook
And that is all you can do.
It would be far easier to just buy a wi-fi router. They are not that expensive.
