I just ran into a backup problem. When I plug in my iPad and start iTunes I get the following error message:
iTunes was unable to load data class information from sync services. Reconnect or try again later.
Does anybody know what this means!
This is a discussion on Ipad backup problem within the iPad Help forums, part of the Apple iPad Discussions category; I just ran into a backup problem. When I plug in my iPad and start iTunes I get the following error message: iTunes was unable ...
Check your cable for damage or try another USB port.Originally Posted by johnl316
I was able to trace the problem to my recent install of Xcode 4.
The installation replaces some files used by iTunes. The fix was to download iTunes and perform a fresh install.
