how to fix keyboard if it hangs
This is a discussion on how to fix keyboard if it hangs within the iPad Help forums, part of the Apple iPad Discussions category; Hi Folks, I discovered a small bug with the iPad2 virtual keyboard, and a simple solution: If the keyboard hangs and you cannot enter data, ...
Results 1 to 5 of 5
    59193
    May 2011
    germany
    7
    If the keyboard hangs and you cannot enter data, and it wont lower using the lower keyboard button just do this:
    1) hit the home button
    2) go to settings -> general -> keyboard
    3) go to intenational Keyboards
    4) tap on the keyboard mentioned (usually english)
    5) choose any different Hardware Keyboard Layout (it is default set to U.S.)
    6) exit settings and the problem should be solved.
    7) if you want to use the U.S setting then go back and set it, the problem stays solved!
    its simple and it works.. I have registered a bug report with apple for this.
    577 times
    Dayton, WA
    13,181
    You did not say, did you try a restart and it did not fix the problem; a complete shutdown by holding the power button until the power off slider appeared?
    This usually fixes glitch problems like the one you described.
    58209
    May 2011
    Germany, Paderborn
    26
    Mine has yet to hang but I would assume it has more to do with the application you're using it with..
    59193
    May 2011
    germany
    7
    Quote Originally Posted by twerppoet
    Hi iPadMaster, actually yes that had been tried, and it did not work. The problem occurred only on new devices where the user had never gone into the keyboard settings. Also if the user had a emoticon app that changes the keyboard setting then the problem didn't happen there either. So we are certain it was not an app problem as such. Another point is that it occurs in several completely different apps. But as mentioned again not on iPads where the user had changed the keyboard settings at least once.
    577 times
    Dayton, WA
    13,181
    Quote Originally Posted by iPadTester
    Ok, thanks for taking the time to explain and expand. I hope Apple saw your report and has had time to squash it in OS 5.
  1. Internet hangs up
    By Mlmotter in forum iPad General Discussions
    Last Post: 06-08-2011, 08:14 PM
  2. Sync hangs forever; iOS4.3, MacKeeper?
    By Evan2 in forum iPad General Discussions
    Last Post: 05-26-2011, 05:50 AM
  3. Replies: 1
    Last Post: 05-19-2011, 11:28 PM
  4. Replies: 4
    Last Post: 05-04-2011, 02:49 AM
  5. Replies: 10
    Last Post: 03-18-2011, 02:12 PM
fix keyboard on ipad
how do i lower the keyboard on ipad2
how to fix ipad keyboard
how to lower keypad on ipad
ipad keyboard freezing
ipad keyboard glitch
iphone 4 keypad not working
iphone keyboard locks up
iphone keyboard not working
keyboard freezes on ipad
keyboard hang
keyboard hangs
Tags for this Thread
