Usb wireless connection lost after ipad connected to pc
This is a discussion on Usb wireless connection lost after ipad connected to pc within the iPad Help forums, part of the Apple iPad Discussions category; Hi, Ive had my iPad since about last August and love it. I have never put any music or videos on it, nor have i ...
Results 1 to 5 of 5
    16450
    Oct 2010
    6
    Hi,
    Ive had my iPad since about last August and love it. I have never put any music or videos on it, nor have i updated it through iTunes (which i hate, rather HATE, through prior experience with iPhone).
    I am moving away and finally decided to connect the ipad to my pc. I just updated my pc with xp service pack 3. When i connect the ipad to the pc, im lucky if iTunes recognizes it (maybe 1/5 times) and it tells me that it requires an update.
    I agree to the update but within a few minutes my internet connection is lost. This pc is on a wireless connection. The wireless is still active as my iPad still has internet as well as the other hard wired pc in the house.
    Even if i do not open iTunes and initiate the "download and install updates" option, my Internet connection is lost on this pc. The computer no longer recognizes my wireless usb key, and the only solution is to restart the computer, nothing else seems to work.
    Obviously the iPad update has not occurred since the internet is lost within 2-3 minutes of starting the update!
    I am at my wits end with this iPad. I just want to update it, and then transfer some music and video to it- doesn't seem like too much to ask. I have previously been using it only for a few small apps and an ereader.
    I have ESET NOD 2 AV with no spyware or malware issues im aware of.
    Also: can someone tell me how to scroll efficiently in embedded text boxes like this? It is very slow and difficult to scroll in this window.
    Thanks all.
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Try downloading the 4.3.3 firmware directly from the appropriate link (top one I think) in our thread here to your desktop...
    Official Apple IOS Firmware Download Links for iPad
    If you have problems, make sure you temporarily DISABLE your anti-virus.
    Then, once the download is finished, in iTunes, hold down the shift key as you click the "update" button for your iPad. This will open a dialogue box and allow you to SELECT the firmware file you just downloaded to your desktop. That should allow the process to go through without a hitch.
    And scrolling in text boxes is done with a two-finger scroll on the iPad. Hold down two fingers in the box and drag...
    iPad Enthusiast!
    49296
    Ottawa
    45
    If I put my iPhone too close to my laptop, it kills my wifi connection, not always immediately, but it's predictable. I haven't had the same problem with my ipad2, but it's something to consider.
    Rog
    Rog is offline
    59399
    May 2011
    USA
    114
    F(x),
    It sounds like a USB issue on your pc to me. You mentioned that you "just updated" your laptop to xp sp3. I'd check and/or update your USB drivers. Maybe try another USB port on your pc. I've had worn out USB ports that don't get a reliable physical connection.
    Here is an article on cleaning up old device drivers in xp.
    Removing unused device drivers from Windows XP machines | TechRepublic
    16450
    Oct 2010
    6
    THanks for the advice.
    I was able to update the iPad by downloading and updating separately. The connection issue still happens, I've tried switching the USB ports etc with no change. But it's only the wireless that goes now, the keyboard/mouse keep working.
    Thanks, I'll try cleaning up the old drivers, that definitely could be an issue.
  1. Wireless connection to hdmi
    By Jbembenek in forum iPad Help
    Last Post: 04-14-2011, 08:23 AM
  2. wireless connection problem
    By shmily616 in forum iPad Help
    Last Post: 04-06-2011, 10:00 PM
  3. ipad Camera Connected???
    By HarlyFan in forum iPad Help
    Last Post: 07-12-2010, 08:16 AM
  4. When iPad connected to iTunes
    By Mic in forum iPad Help
    Last Post: 07-02-2010, 12:27 PM
  5. Replies: 2
    Last Post: 05-06-2010, 04:20 PM
connect ipad through a usb to a pc for internet connection
connect ipad to computer wireless
connect ipad to pc wireless
ipad no wireless connection after downloading ios 6.0
lost wifi on ipad when connected new pc to wifi
updated ipad lost wireless
updated itunes and lost wireless connection
usb ipad to pc for internet
wifi connection lost after itunes
windows connect ipod lost usb wireless
wireless connection lost when iphone is plugged in to computer
wireless connection pc and ipad
