Need help with itunes on ipad2
This is a discussion on Need help with itunes on ipad2 within the iPad Help forums, part of the Apple iPad Discussions category; Sorry, I know this is probably very basic, but I can't for the life of me figure it out! I have an iPad 2, my ...
Results 1 to 8 of 8
    40726
    Michigan
    161
    Sorry, I know this is probably very basic, but I can't for the life of me figure it out! I have an iPad 2, my daughter has an iPod touch (4th gen), she has her songs, I have mine and we have iTunes set for both devices to manage them manually....but HOW can I get her songs on my iPad?? When my iPad is hooked up I don't even SEE her songs on the music list? I don't want all of her music, just select songs but once her iPod is unplugged from the computer and my iPad is plugged in I no longer see her music at all. If anyone can help I appreciate it! I know this has to be easy and I shouldn't have to purchase songs twice. Annette
    iPad Enthusiast!
    22751
    Nov 2010
    Arizona
    90
    It should'nt have anything to do with what's on your daughter's device. It's what's in iTunes that matters. You should be able to select (manually) what you want to sync, no matter what device. When you plug your device into iTunes, select your device after it pops up in the left margin. A window comes up where you select manually whatever you want to sync. I have no problems with both mine and my wife's iPod and my iPad2.
    56429
    May 2011
    Delaware
    8
    Quote Originally Posted by Videographer View Post
    ^^ Yup, what he said.
    579 times
    Dayton, WA
    13,188
    It does not sound like you are actually syncing the music to iTunes at all. You are just looking at what is on the device when it is plugged in.
    Try this.
    With you iPod or iPad connected, right click on it under the Device list and choose Transfer Purchases. This should copy the music (and othe stuff) to the iTunes library. When it is done, unplug and see if the music is there. If so you should now be able to copy music to the other device.
    You will need to do this with both devices to make all music available to both devices.
    40726
    Michigan
    161
    Thank you! It worked for a select few songs...haven't figured out why the others won't transfer. Odd
    579 times
    Dayton, WA
    13,188
    If you used some method other than iTunes (on the iPad or on the computer) to place the songs on the device, they may not transfer to iTunes. If you have used more than one account to place music on the device, you can only transfer those songs if you have the same account authorized in iTunes (not certain about that, but pretty sure).
    Other than that, I'm not sure why the would not transfer. It shouldn't hurt to try more than once.
    40726
    Michigan
    161
    Ok, thanks!
    Banned
    48444
    Wales
    667
    Or perhaps you have not ticked the items prior to sync ?
  1. iPad2 to itunes sync issues
    By chrisandsarah06 in forum iPad Help
    Last Post: 08-04-2011, 04:08 AM
  2. Transfer Itunes from PC to Ipad2?
    By csrredcoat in forum iPad 2 Forum
    Last Post: 05-30-2011, 09:12 AM
  3. ipad2 and itunes on windows 7
    By derek71245@gmail.com in forum New Member Introductions - Site Assistance
    Last Post: 05-12-2011, 11:06 AM
  4. Ipad2 not recognised with iTunes
    By Kevin41 in forum iPad 2 Forum
    Last Post: 04-13-2011, 08:31 AM
  5. itunes not seeing new ipad2?
    By sjleworthy in forum iPad 2 Forum
    Last Post: 04-12-2011, 10:41 AM
can't find songs after itunes download on ipad2
can't select my ipad in itunes left
can't select song list ipad 2
cant see music videos on ipad2
doeas ipad 2 have itunes
does ipad 2 have itunes
does ipad2 have itunes
how can i get my songs on my ipad2 from itune
how should i have my setting on ipad2 to get my songs off itunes
ipad 2 cannot find my downloaded music on itunes
itunes can't select anything ipad
itunes for ipad2
