Originally Posted by
idave23
I've never used Skype before so I'm not familiar with how it works other than it's supposed to be easy to use with an iPad. I went ahead and download the app based on the raves people give it here. From what I read in the description it's free if the person you call also has Skype right?. It also says you can call or text other contacts at low rates with Skype credit. I didn't give a credit card # when I signed up but was able to make a call to my wife's cell that wasn't using Skype. So my question is how does it charge you if you make a call to a phone that's not using Skype?
As you'll have found, the app for the iPad is not iPad-specific - it was actually designed for the iPhone but works just fine on the iPad - although the app doesn't fill the iPad screen properly. You can call - over the Internet - another user who has Skype on their PC, iPad etc for free - always - irrespective of where in the world they are
You can also call regular phone numbers - mobile or regular - but you are charged. As the other poster suggested, Skype give you a small 'free' initial credit so that you can check it out. Once that initial credit is used up, you will
need to give credit card details to be able to continue.
While not wishing to contradict the other poster, I would suggest that this is precisely the right Forum for your question - since it relates to using an iPad
and most certainly this is the best iPad Forum there is!! You'll find many threads in this Forum on using Skype on the iPad - including the answers to
many questions and problems that people have had - using Skype with the
iPad video cameras, for example. Have a look around and please stay with us.
Welcome to the Forum
