Why my ipad2 timezone auto change to another countries timezone when im not overseas?
This is a discussion on Why my ipad2 timezone auto change to another countries timezone when im not overseas? within the iPad Help forums, part of the Apple iPad Discussions category; Why my ipad2 timezone auto change to another countries timezone when im not overseas? I'm the setting when I set it automatically it it will ...
Results 1 to 9 of 9
    58794
    May 2011
    Why my ipad2 timezone auto change to another countries timezone when im not overseas? I'm the setting when I set it automatically it it will change to other timezone that different from my current location.(I'm in London) Also when I sync with my Mac the timezone will change after sync. I can only set the time manually, but there's another problem is when I use my Facebook or twitter I can't see what time is the post that my friend posted. Eg: 15minutes ago. Can someone help me out or somebody encountered the same problem as me?
    58794
    May 2011
    These pictures are my settings. Manually time is correct but aster i pressed set automatically became other timezone. Please help..this bothering me...
    Attached Thumbnails Attached Thumbnails Why my ipad2 timezone auto change to another countries timezone when im not overseas?-image-4196524407.png   Why my ipad2 timezone auto change to another countries timezone when im not overseas?-image-4098998465.png   Why my ipad2 timezone auto change to another countries timezone when im not overseas?-image-1170424597.png
    580 times
    Dayton, WA
    13,192
    Open the Map app. Where does it think you are located?
    Also, try changing your time zone under Settings >> Mail, Contacts, Calendars >> Time Zone Support. That might help the second problem, and might not.
    580 times
    Dayton, WA
    13,192
    As a temporary fix you might be able to go to Settings >> Locations Services, and turn it off. You probably won't want to keep it this way, because it will limit quite a few useful apps from working properly, including the Maps app.
    58794
    May 2011
    Hi thanks for your reply I've tried everything you mentioned above but still don't work well for me. And my current location in maps app also the right location as where I'm ATM.
    580 times
    Dayton, WA
    13,192
    Ok, that pretty much exhausts my ideas. One last thing to try, and for something like this I don't hold out much hope, is a reset.
    Hold down the power and home buttons until the Apple logo appears (ignore the power off slider if it appears). The iPad should reboot.
    58794
    May 2011
    I've tried that too.. Thanks for your reply , appreciate it. Atone encountered the same problem as I am?
    Rog
    Rog is offline
    59399
    May 2011
    USA
    114
    I would suggest verifying that you have the correct timezone set on the laptop or PC that you sync with.
    13151
    Aug 2010
    Australia
    8
    Go to your ipad Settings>General>Reset>Reset Location Warnings
    Message pop up, click reset and check your time and map location if this help.
  1. Timezone issue via ics for ipad2
    By JonL in forum iPad Help
    Last Post: 12-14-2011, 03:37 PM
  2. Using simcard overseas
    By Jane O in forum iPad Help
    Last Post: 04-21-2011, 08:39 PM
  3. Replies: 4
    Last Post: 03-06-2011, 01:53 AM
  4. NETFLIX Overseas
    By Mickeybros in forum iPad FAQ
    Last Post: 01-26-2011, 03:04 AM
change time zone on ipad
does the ipad change time zones automatically
how do i change the time on my ipad 2
how do i change the time on my ipad2?
how do i fix the time on my ipad2?
how to change time on ipad 2
ipad wont change time zones
ipad wont change time zones keeps spinning
my ipad won't follow my time zone
reset ipad time zone
will my ipad clock change when i cross time zones
will the time on the ipad auto change
