So I intend to load movies onto SD card and use via the CCK but I was wondering what the largest card that people have used on here are?
Im looking to buy a large SD card and wanted to know what the biggest was.
Cheers,
Davies
This is a discussion on Largest SD card used with a Camera Connection Kit within the iPad Help forums, part of the Apple iPad Discussions category; So I intend to load movies onto SD card and use via the CCK but I was wondering what the largest card that people have ...
Cheers,
Davies
32Gb is the largest card, by spec, that you can use.
What class memory is required to transfer data at proper speed?
Please Support the Wounded Warrior Project
iPod 2nd 8GB, iPod nano 6th 16GB, iPod Classic 7th 160GB, iPhone 4 x 2 16GB, iPad 1 32 GB & iPad2 32GB Blk, 1 iPad 3 32GB Wifi 4G and a iPad 3 64GB Wifi.
Shouldn't matter, as long as you aren't using some ancient 1st generation SD card. The iPad's connector isn't high end camera fast, so super fast SD cards would probably just be a waste of money, unless you're using a super fast high end camera, of course.![]()
