Ipad 3G / WiFi Help
This is a discussion on Ipad 3G / WiFi Help within the iPad Help forums, part of the Apple iPad Discussions category; The problem my friend is my iPad does no longer have a wifi I don't have a weak wifi reception!! I am not being able ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    Jad
    Jad is offline
    4214
    May 2010
    Amman
    Wifi-less
    I am not being able to switch it on or off, that what makes me worried as it didn't happen at once
    First wifi is great
    Then wifi is weak
    Then wifi does not find anything
    Then no wifi
    I don't think it's software
  3. #12
    4776
    May 2010
    Hutchinson, KS
    I am trying to role out iPads for doctors in my hospital. Dr has iPad with 3G+WiFi. I have iPad with WiFi only. My iPad has been working fine for 2 weeks. Dr's iPad worked well for first 3 days but hasn't been able to stay connected to WiFi since. I can stand right next to him and get WiFi connection. When he tries, he gets connected for about 7 seconds but then the searching icon appears and he is kicked off. The only difference between our two iPads is he has 3G and a bunch of downloaded apps (don't think the apps have anything to do with it). I have updated firmware on all routers but can't reset to factory defaults because that would disable devices used to actively monitor patients.
    Any ideas?
  1. WiFi Ipad on an airplane?
    By JBUNGIE in forum iPad General Discussions
    Last Post: 05-05-2010, 06:37 PM
  2. Wifi vs 3G wifi speed/reception
    By CPMS in forum iPad General Discussions
    Last Post: 05-03-2010, 10:25 AM
  3. WiFi VS. WiFi + 3G WiFi Issues
    Last Post: 05-01-2010, 12:26 PM
  4. Will you try to exchange your wifi to 3G iPad?
    By dabears in forum iPad General Discussions
    Last Post: 04-29-2010, 04:54 PM
  5. WiFi VS. WiFi + 3G Release
    Last Post: 03-11-2010, 01:48 AM
ipad join network greyed out
ipad join wifi greyed out
ipad join wireless grey out
ipad join wireless network grayed out
ipad wifi greyed out
ipad wifi vs 3g in new york city
join grayed out on ipad
my ipad is unable to join my network
unable to connect 3g after turn off wifi ipad
unable to get ipad 3g connection
unable to join network ipad how to connect to wifi
wifi grayed out on my ipad
