Ipad 2 help wifi help 4.3.3 pleaseee
This is a discussion on Ipad 2 help wifi help 4.3.3 pleaseee within the iPad Help forums, part of the Apple iPad Discussions category; Hello. First off thank you for helping me in advance. I just got a Ipad 2 (32gb wifi only) and its not connecting to my ...
Results 1 to 10 of 10
    57731
    May 2011
    Hello.
    First off thank you for helping me in advance. I just got a Ipad 2 (32gb wifi only) and its not connecting to my router. I have another ipad but its the first one and it works fine. The ipad 2 i just got does not connect to my wifi router. The ipad 2 has the 4.3.3 os on it. When i first tryed to connect the ipad 2 to the router, i put the password in it would say i was in but then a second later it would just say not connected no matter how many times i hit the wifi router name. Then i went online to try and fix it and did everything i saw. Things like a hard reset,turn wifi on/off, forget network,rener lease,reset router, take plug in and out of router,etc but nothin works. Now the ipad holds the wifi sometimes and has the wifi bars in the top left but when i go to safari or youtube it says it cant cnnect. Also when i go to th wifi name and press the blue arrow, only the ip address and subnet mask has numbers next to them. Could that be an issue? Please help me i know this is a problem with the 4.3.3 os but can someone help me because it seems like i have tryed everything that worked for everyone else but me. Thanks again.
    36325
    3 times
    Bay Area
    957
    You might want to try Settings/General/Reset/Erase All Content and Settings before taking it in.
    57731
    May 2011
    why do u say that? Also i am on a verizon fios router if that makes any difference
    577 times
    Dayton, WA
    13,181
    It doesn't have anything to do with the 4.3.3 update. iPads have had problems with some routers, and it's been fairly unpredictable when and where. Yes, even when one iPad works and another does not.
    Here is a fairly good list of things to try, if you haven't tried them all yet.
    http://www.ipadforums.net/ipad-2-for...-problems.html
    36325
    3 times
    Bay Area
    957
    Yes, quite right... it is very likely a router issue. I was assuming that the iPad was not connecting at all (anywhere) and suggested the reset as a last ditch measure.
    577 times
    Dayton, WA
    13,181
    But the reset you suggested would take it back to defaults, and erase pretty much everything. Normally you would only do that if you were selling or returning the iPad.
    Just below it is the Reset Network Settings. Perhaps that is what you meant to suggest?
    36325
    3 times
    Bay Area
    957
    Quote Originally Posted by twerppoet
    Perhaps I should have recommended that first; but, I understood that he had received it recently and, under the circumstances, resetting it to the defaults might have been an approach.
    577 times
    Dayton, WA
    13,181
    Could be. Guess we'll have to wait until OP comes back and lets us know how things are going.
    Hopefully a solutions has been found.
    36325
    3 times
    Bay Area
    957
    No news is good news? :-)
    43380
    USA
    11
    I am keeping this thread bookmarked.
  1. Replies: 50
    Last Post: 10-12-2012, 10:42 PM
  2. Intermittent Wifi issues with iPad 2 and WiFi
    By MarilynLockhart in forum iPad General Discussions
    Last Post: 04-24-2011, 11:11 PM
  3. iPad WiFi/3G vs. iPad WiFi + Verizon MiFi/Sprint Overdrive etc?
    By MachThree in forum iPad General Discussions
    Last Post: 12-18-2010, 05:02 PM
  4. Sold my 16gb wifi and wait for 32gb wifi is killing me
    By Ian B in forum iPad General Discussions
    Last Post: 06-29-2010, 06:19 PM
  5. Setting up Verizon Blackberry Tour Wifi Hotspot for Ipad Wifi
    By xlr8nflorida in forum iPad General Discussions
    Last Post: 06-14-2010, 11:09 PM
fios and ipad2 connection
how to know the password of the connected router from iphone 4.3.3
how to setup a wifi password on ipad 2
intermittent fios connection on ipad
ipad 2 help wifi
ipad 2 help wifi help 4.3.3 pleaseee
ipad 2 initial setup wifi
ipad and verizon fios wifi problems
ipad not finding network 4.3.3
overdrive download waiting for wifi
overdrive waiting for wifi
trouble connecting 2nd ipad to fios router wifi
