This just happened to me last night - thank you so much sarah and col.bris! worked perfectly! I'm bookmarking this sight now!
This is a discussion on Safari problems within the iPad Help forums, part of the Apple iPad Discussions category; This just happened to me last night - thank you so much sarah and col.bris! worked perfectly! I'm bookmarking this sight now!...
Thank you the soft reset worked like a charm........
Just do a reset home button and off key until white apple logo appears. It may be another app causing issue.
This worked!!! Thanks!!!
Safari problems solved. I just did what you wrote Sarah, thank you!![]()
Thanks for Sarah's advice; pressing the both function keys until the Apple showed up solved this for me. The gray screen is gone and Safari is back up and running.![]()
