Problem sending email on 3G
This is a discussion on Problem sending email on 3G within the iPad Help forums, part of the Apple iPad Discussions category; I have an iPad 1 and have set up 2 imap mail accounts, I use it a lot to receives mail whilst out and about ...
Results 1 to 3 of 3
    56806
    May 2011
    I have an iPad 1 and have set up 2 imap mail accounts, I use it a lot to receives mail whilst out and about but have noticed that I can send or receive with no problems when at home on wifi but can only receive mail when using 3G network. I get the message ' the connection to the outgoing server "smtp.ntlworld.com" failed. Additional outgoing mail severs can be configured in settings> mail, contact, calenders.' Any help would be greatly appreciated.
    116 times
    15,249
    I think this may be the famous 'Port 25 relay' problem. Does your ISP support SSL and other port numbers? The problem is that, when you're 'out and about' the ISP can't verify your identity using SMTP and 'Port 25'. Because you don't have to supply a password for SMTP on Port 25 the ISP cannot be sure you say who you say you are. So you need to switch to a protocol that has SSL - most ISPs do - if your ISP doesn't then send via Google; they support SSL and I've used them without any problems...
    56806
    May 2011
    Quick follow up for anybody having trouble sending mail via ntlworld. It would appear that anybody using the old ntlworld.com emails can't send mail on 3G as they do not support password authentication. Changing the following settings has solved the problem for me.
    Change the outgoing server from smtp.ntlworld.com to smtp.virginmedia.com.
    Put in you username ending with .ntlworld.com.
    Enter you password.
    Set use SSL to on.
    Go into authentication and click 'password'' when you back it should now say password in the authentication box.
    Change server port to 465.
    Click done and it should work, well it did for me.
    Hope this helps.
    Mark
  1. Email sending problems
    By lifeisabeach in forum iPad Help
    Last Post: 05-17-2013, 02:08 AM
  2. Sending Email from a different wifi
    By PCUK in forum iPad Help
    Last Post: 05-01-2011, 06:16 AM
  3. Sending email thru Netgear wnr2000v3
    By Dalford in forum iPad Help
    Last Post: 03-24-2011, 05:48 PM
  4. sending email
    By april in forum iPad General Discussions
    Last Post: 11-09-2010, 12:14 PM
  5. Sending reports from Pages to my email...
    Last Post: 08-18-2010, 09:21 AM
can i send email with 3g
ipad can't send email over 3g
ipad cant send email on 3g
ipad not sending email on 3g
ipad on 3g will not send email
ipad will not get emails on 3g
iphone can't send email on 3g
iphone not sending emails on 3g
iphone will not send email 3g
mail not sending 3g ipad
sending mail on ipad through 3g
using 3g for iphone mail
