Apps won't load
This is a discussion on Apps won't load within the iPad Help forums, part of the Apple iPad Discussions category; Got my 32GB ipad back in November 2010. No problem until a couple of weeks ago when for no reason applications won't start. Two I ...
Results 1 to 5 of 5
Thread: Apps won't load
    17987
    Oct 2010
    Singapore
    Apps won't load
    Got my 32GB ipad back in November 2010. No problem until a couple of weeks ago when for no reason applications won't start. Two I paid for, Molten (a drum box) and the game Arkanoid, two I got free, Angry Birds Seasons and VLC.
    Same thing happens for all of them, first they open up, they seem to be loading, and then they disappear.
    I uninstalled and re-installed them, to no avail.
    Anyone encountered the same problems? Anything else I should try? Thanks for your help.
    116 times
    15,249
    17987
    Oct 2010
    Singapore
    It worked. I didn't know about the need to switch off the ipad once in a while. I'll remember that one.
    Thanks for your help Tim.
    225450
    Jul 2012
    Oklahoma City, OK
    Not working
    I tried both of these methods and it is not working. I did not have this problem until OS 5 on iPad1. So far only noticing on new apps and not all. Any thoughts?
    271982
    Jan 2013
    Brooklyn ny
    I'm having the same problem, did you get help
  1. My apps say waiting and wont load?
    By Shiny in forum iPad Help
    Last Post: 05-16-2012, 05:13 PM
  2. What will be your first (3) movies,apps & pictures you load?
    By Isaac Newton in forum iPad General Discussions
    Last Post: 01-20-2012, 08:04 PM
  3. ABC app won't load programs
    By GingerGirl in forum iPad Apps
    Last Post: 06-23-2011, 08:17 AM
  4. Please help. Some images won't load.
    By Nemius in forum iPad Help
    Last Post: 05-13-2011, 08:36 AM
  5. Down load mp3 file
    By paulyeo11 in forum iPad General Discussions
    Last Post: 08-27-2010, 04:25 PM
app won't load on ipad
apps wont load on ipad
ipad app won't load
ipad app wont load
ipad apps do not load
ipad apps will not load
ipad apps won't load
ipad will not load apps
ipad won't load apps
ipad wont load apps
twitter wont load on ipad
why won't my apps load on ipad
