Checklist for troubleshooting Wi-Fi connection problems.
This is a discussion on Checklist for troubleshooting Wi-Fi connection problems. within the iPad Help forums, part of the Apple iPad Discussions category; I have had problems with a dropping internet connection since day one I had the Ipad. I did a lot of reading and found a ...
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 49
Like Tree1Likes
Thread: Checklist for troubleshooting Wi-Fi connection problems.
    45436
    3 times
    Thailand
    388
    I have had problems with a dropping internet connection since day one I had the Ipad. I did a lot of reading and found a lot of suggestions. The strange thing is that according to the answers for some people these individual suggestions helped. In my case unfortunately they did not.
    I will try to list done all the things that I have read and or tried myself. If you feel up to it you can try them yourself. Since many threads handle this subject I would appreciate it if you only mention if a certain solution works for you. Not if it doesn’t. If people have other suggestions please feel free to add them.
    Before trying anything below make sure your router has the latest firmware.
    Ipad:
    Reset Network settings
    Settings/General/Reset/Reset Network Settings. This will NOT delete your apps, music, etc.
    Press simultaneously the power and home button for 7 seconds. This will reboot the IPad.
    Connect to your Wi-Fi
    Push Notifications:
    Princeton IT suggested as a work around to turn these notifications off.
    Workaround for "iOS 4.1 - 4.3.3 Allows DHCP Lease to Expire, Keeps Using IP Address" Bug
    DHCP
    Use a fixed IP address
    Settings/WiFi/click on the arrow of your Wi-Fi connection/Static/
    Fill in the IP-address, subnet, routers IP and DNS
    DNS
    Some mentioned that using Google’s’ DNS worked for them
    Type this in the DNS field: 8.8.8.8, 8.8.4.4
    Magnet
    Magnets and electronics do not like each other. It could be that the smart covers are creating some sort of interference. I modified an Ipad case, by adding a small magnet and I do have the feeling (no real proof) that the Ipad disconnects less often without the case. (It still disconnects though.)
    Router
    The following suggestions require some basic knowledge of your router. I suggest that before you do any of the suggested changes you make a backup of your routers configuration first. That way you can easily restore your old settings.
    Since there are many routers available, with each his own layout I will not go into the details. Read the manual of your router to see where you can apply these changes.
    Some users have replaced there older router with a new model and this soved their problem.
    Dual band
    Modern routers have dual band (2.4 and 5 GHz). Try using a single band
    Also some routers have a dual range of 20 and 40 Hz. Try switching to 20Hz only
    QoS (Quality of Service)
    I believe on some routers this is called WMM as well
    Some users say switch it on, some say switch it off. I tried both without success
    Security
    Switch from WEP to WPA2
    Today I read on Apple support the suggestion to turn security off and use MAC address access. I have not tried this yet, but will do this tonight.
    Power off
    Some suggested to reset the network settings on your Ipad (see above) and switch off the router for 60 seconds as well.
    If I find other possibilities I will add them here.
    Good luck.
    Last edited by DM51; 05-20-2011 at 12:00 PM. Reason: (Readability - DM51) Previous edit by OP: Corrected the Reset Network Settings . Thanks Twerppoet
  2. #2
    55902
    May 2011
    I have 2 IPod Touch's, 2nd gen and 3rd gen and an Ipad2. My connection was dropping on all 3 for several weeks. Replaced the router with a new one, and have not had a drop on any of them in 5 weeks. My router was 4 years old.
  3. #3
    iPad Master!
    37720
    4 times
    Colonial Heights,Va
    1,367
    Mine has been unsuccessful in my attempts but I will delete Whistle, which looks for incoming phone calls and turn off notifications, both suggested in the link and I haven't tried them . I will post back the results.
    Since mine is intermittent with no pattern I'll give it a day before posting back
    Thank you for the thread, hope they make it a sticky
    Support Our Troops!!
    This post was Tapatalk approved. Sent from an Incredible phone
  4. #4
    45436
    3 times
    Thailand
    388
    Quote Originally Posted by lees View Post
    Thanks, read about this also, but forgot to add. This is done now.
  5. #5
    iPad Master!
    37720
    4 times
    Colonial Heights,Va
    1,367
    Well I can report it did not work. Bummer
    Edit: forgot to turn off " find my iPad" trying again with Whistle gone, notifications off and find my iPad off.
    After further reading I think I understand why mine ,4.3.2, does it on many networks and my wife's on 4.2 doesn't on any. It seems the newer the firmware the longer between leases it affects. I've got mine set for 24 hours
    Support Our Troops!
  6. #6
    18578
    4 times
    Oct 2010
    Virginia, usa
    564
    Quote Originally Posted by JJK View Post
    Power off
    Good luck.
    I would suggest that you turn off and unplug your router for 8 to 10 min. This allows the capacitors to discharge fully so you get a full reset of it's memory. That way you can be sure the memory is cleared completely, and you are getting a clean boot-up of the router. Same holds true for PC/MAC, when having weird problems.
    iPad 64gb 3g, iPhone4 32gb, iPod Touch 32gb, Classic iPod 30gb, AppleTV 1g and 2g
    http://manuals.info.apple.com/en_US/...User_Guide.pdf
    Good Luck
    Pocobear
  7. #7
    32660
    Feb 2011
    129
    Had intermittent problems until Upgrading router and added an extension to reach back of house.
  8. #8
    iPad Junkie!
    51269
    May 2011
    122
    We had trouble with all wifi devices in the house on a very inconsistent basis, and it turned out to be the router getting flakey. I replaced it and everything is rock solid now again. The sort of frustrating thing was that it was very inconsistent - sometimes it seemed to be working fine, other times it would drop connections on a random basis.
  9. #9
    iPad Junkie!
    51269
    May 2011
    122
    You may also be able to do a hard reset on the router, which sometimes involves holding the reset button before and during power-up.
    Quote Originally Posted by Pocobear View Post
    Power off
    Good luck.
  10. #10
    45436
    3 times
    Thailand
    388
    Did that work for you, or is it just a suggestion? The things i listed really did solve the problem for the person that mentioned it. Still, it doesn't hurt trying.
Sponsors
  1. PC connection problems
    By turner in forum New Member Introductions - Site Assistance
    Last Post: 11-06-2011, 07:07 AM
  2. Problems with camera connection kit !
    By Andy Loba in forum iPad OS
    Last Post: 04-20-2011, 10:09 PM
  3. Looking for a particular to do / checklist app
    By MSguywithiPad in forum iPad Apps
    Last Post: 04-19-2011, 08:11 AM
  4. Connection Problems
    By Al Rogers in forum iPad Help
    Last Post: 01-04-2011, 06:38 PM
  5. connection kit problems
    By samsberr in forum iPad Accessories
    Last Post: 06-14-2010, 05:32 PM
apple ipad 2 troubleshooting
ipad 2 internet connection
ipad 2 internet connection issues
ipad 2 internet connection problems
ipad 2 internet problems
ipad 2 troubleshooting safari
ipad 2 troubleshooting wifi
ipad 2 wifi connection problems
ipad 2 wifi troubleshooting
ipad connection problems
ipad internet troubleshooting
ipad troubleshooting wifi
ipad troubleshooting wifi connection
troubleshoot ipad 2 wifi
troubleshooting ipad 2 wifi
troubleshooting wifi connection problems
wifi
