Home button doesn't bring up red slider
This is a discussion on Home button doesn't bring up red slider within the iPad Help forums, part of the Apple iPad Discussions category; Does anyone else have this problem? I can reboot when I use on off switch and home button at the same time but slider never ...
Results 1 to 10 of 10
    56427
    5 times
    May 2011
    265
    Does anyone else have this problem? I can reboot when I use on off switch and home button at the same time but slider never comes up anymore just holding home button.
    iPad Guru
    30446
    11 times
    3,197
    This may be a slight confusion of home and power button. Have you tried holding the on/off switch for 5 seconds? This should bring up the slider to turn of the iPad.
    56427
    5 times
    May 2011
    265
    My understanding is that you hold down the home button (the one on the bevel with the square on it) for a few seconds to bring up the slider. If that doesn't work, then you can hold the on/off switch on the side silver part and the home key with the square to reboot which I just did a little while ago and that worked. Is this indicative of a bigger problem?
    iPad Guru
    30446
    11 times
    3,197
    Well, therein lies the problem.
    To reboot, you hold the on/off switch for a few seconds.
    For a hard reboot, you would press both, the on/off switch and the home button.
    Pressing the home button alone only brings you back to the home screen, but it will never let you reboot. That's what the on/off switch is for.
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Quote Originally Posted by NYHorsewoman View Post
    I'm afraid your understanding is wrong. Holding down the home button on any iPad has never brought up the red slider. You must hold down the sleep/power button. I apprecaite you maybe think you were holding home before, but I assure you this has never been a feature of any iPad or iPhone. You just have your buttons mixed up. Try holding down the sleep / power button now. After a few seconds the slider will appear.
    56427
    5 times
    May 2011
    265
    Wow, thanks. Hard to believe that I can take apart any windows PC and put it back together and trouble shoot everyone else's computer problems. Thanks very much.
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    We all have moments like those, I promise you!
    26626
    20 times
    Dec 2010
    North Carolina - US
    1,545
    Just for future reference here is a screenshot from the manual. I been there and don't that my friend.
    iFrog - Sent from my iPad2 using iPF
    Attached Thumbnails Attached Thumbnails Home button doesn't bring up red slider-image-516866232.png
    iFrog - Ernie
    iPad Forums Moderation Team
    iMac 27" mid 2011 i7 3.4GHz, 16GB Ram, 2TB HD and 1GB Video Card
    iPhone 4S Black 32Gb - iOS 6.0.1 - iPad Mini Black 64GB Wifi - iOS 6.0.1
    Forum Rules. Please Read - Hacking Section Rules
    56427
    5 times
    May 2011
    265
    thanks all! Appreciate it.
    11919
    9 times
    Aug 2010
    Virginia, USA
    718
    Refer to page 10 of your
    iPad2 4.3 users guide.
    If my Irish Wolfhound doesn't like you neither will I.
    2012 13" MBA, 2011 11" MBA, 2010 15" MBP, 2 iPad3s, 1 iPad Mini, iPhone 4S and iPhone 5. A bunch of iPods and an Apple TV.
  1. on/off button doesn't work
    By ceedog in forum iPad Help
    Last Post: 05-29-2011, 05:12 PM
  2. Volume button doesn't mute
    By BC1973 in forum iPad Help
    Last Post: 05-16-2011, 08:19 AM
  3. Home button
    By DontUnderstandMyIpad in forum iPad 2 Forum
    Last Post: 03-25-2011, 05:32 PM
  4. Home Button
    By tnbug in forum iPad 2 Forum
    Last Post: 03-06-2011, 08:23 PM
  5. Replaced Home Button?
    By Ultrimate in forum iPad General Discussions
    Last Post: 09-19-2010, 06:57 AM
ipad 2 red slider does not appear
ipad no red slider
ipad power button doesnt appear
ipad red slider does not appear
ipad red slider doesn't appear
iphone no red slider
iphone red slider does not appear
no red slider iphone
no red slider on iphone
red slider wont show up
turning off iphone red slider never/appears
what do you do if your ipad slider wont appear
