Ipad and forum problem.
This is a discussion on Ipad and forum problem. within the iPad Help forums, part of the Apple iPad Discussions category; I have tried searching the forum for this but no matter how I phrase it nothing comes up although I know I am not the ...
Results 1 to 7 of 7
    55811
    May 2011
    7
    I have tried searching the forum for this but no matter how I phrase it nothing comes up although I know I am not the first to have it.
    I can't use my iPad to post on eBay forums. With my first iPad I could type in the text box but it was invisible but posted ok, now I can't even do that, the keyboard just won't come up. Is there a fix?
    116 times
    15,249
    55811
    May 2011
    7
    Thanks for trying to help but I wasn't having trouble with an app. I use eBay direct from Safari. I have just had to restore my ipad2 from a backup whilst trying to instal 4.3 which I hoped might provide a fix, the whole thing started to go **** up so I had to abandon it. When I plugged the iPad back in it treated as a new one. Hey ho so I restored from a backup and had to reload a couple of new apps. I still can't post on the eBay forum though. Would it work with the eBay app perhaps? A net search brings up lots of people that can't post on various forums but no one seems to have a solution.
    iPad Guru
    30446
    11 times
    3,197
    As far as I can tell, it is an ebay forum problem.
    It doesn't work with Safari, nor does it work with iSwifter, which is the common workaround for pages, which don't work on the iPad.
    The ebay app is only useful for selling, buying and browsing through items, but doesn't include the discussion board, so it won't be of much help.
    This doesn't really much, apart from realizing that it must be a universal problem with the ebay forum.
    55811
    May 2011
    7
    It doesn't appear to be just an eBay forum problem, if you do a net search there appear to be quite a few forums where the iPad won't work. Someone posted that they had sorted it by turning off RTE but I can't find it anywhere on the pad to turn it off. Why I wonder haven't Apple addressed this?
    579 times
    Dayton, WA
    13,183
    It's most often caused by the type of editor the forum uses. Some forums, including this one, let you choose between several editors in their user options. WYSWIG editors are usually the problem.
    I looked over the eBay forum (first I knew there was one), but it does not seem to have any options to set your editor type.
    Safari seems to handle some of the WYSWIG editors a bit better than the third party browses, so if it isn't working then you're probably out of luck. At least until/if, an app is made for the forum.
    55811
    May 2011
    7
    Oh well. One of the main reasons I bought the ipad was to be able to use it in my lounge in the evening so I was able to sit with hubby too. I spend a fair amount of time on one ebay forum in particular and it's a real downer that I can't use it in the evenings.
  1. iPad Forum App
    By slothead in forum Official iPadForums.net App Forum
    Last Post: 12-13-2012, 10:57 AM
  2. Problem entering text in a 'Net forum w/iPad 2
    By k7lvo in forum iPad General Discussions
    Last Post: 04-17-2011, 12:12 PM
  3. New to the forum, I am looking forward to learn and contribute to the forum
    By ExcgsyA in forum New Member Introductions - Site Assistance
    Last Post: 04-06-2011, 11:30 PM
  4. Hi! I'm new to the IPad and the forum!
    By Hoya94 in forum New Member Introductions - Site Assistance
    Last Post: 03-26-2011, 11:10 PM
  5. Forum Navigation Problem
    By kc2ped in forum iPad General Discussions
    Last Post: 09-21-2010, 04:30 AM
can't finish listing on ipad ebay
can't list on ebay ipad
can't type description for ebay item on ipad 2
can't type or select anything on ipad
cannot type in ebay description
cant list item on ebay ipad app
i cant list an item on ipad2 ebay app
i cant list items on ipad
problems with rte ipad app
typing ebay descriptions on ipad
why can't i edit the description of an ebay item i posted with ipad?
why can't i type in text boxes with ipad on ebay
