Problem with PDF rendering
This is a discussion on Problem with PDF rendering within the iPad Help forums, part of the Apple iPad Discussions category; I use Sugarsync to synchronize files on my computer. I scan a lot of documents into PDF and keep them on my computer. They were ...
Results 1 to 2 of 2
    56141
    May 2011
    I use Sugarsync to synchronize files on my computer. I scan a lot of documents into PDF and keep them on my computer. They were previously opening without a problem. But there was a lag because some of the files were quite large. So today I decided to reduce the file sizes by resaving them using Adobe Acrobat's save "Reduced Size PDF" options.
    The files open on my computer without a problem, but when I opened in SugarSync it's just a blank page. After playing around for a while, I decided to email that file to my iPad to see if this is a problem with SugarSync or iPad rendering.
    The emailed PDF is just a black screen as well, so I think it's iPad having trouble opening the file.
    So I wonder what the iPad PDF format requirment is. I re-saved the files using Acrobat 6.x compatibility and still can't open it.
    Any thoughts? Thanks
    19182
    2 times
    Oct 2010
    Israel
    891
    This is a known issue with iPad. It would not show properly some PDF files.
    At one point I even traced it to one kind of PDF files that their properties are shown down below.
    Attached Thumbnails Attached Thumbnails Problem with PDF rendering-pdf1.jpg   Problem with PDF rendering-pdf2.jpg
    Think before you Sync Since you may Sink
    The More Tweaks you have - Less Memory is left
  1. Replies: 9
    Last Post: 05-09-2012, 04:15 AM
  2. Problem with App.
    By NLAlston in forum iPad General Discussions
    Last Post: 04-24-2011, 07:11 PM
  3. BCC problem
    By Dream in forum iPad Help
    Last Post: 12-18-2010, 09:04 AM
  4. problem with 3G!!!
    By bahram in forum iPad Help
    Last Post: 11-01-2010, 06:54 AM
  5. Browser Rendering Help :(
    By kjk34zcvxcv in forum iPad Help
    Last Post: 10-03-2010, 09:35 AM
how to reduce pdf file size for ipad
ipad app to reduce size of pdf
ipad apps for reducing the size of pdf files
ipad pdf rendering
ipad pdf rendering problem
pdf rendering issues in iphone
pdf rendering issues on iphone
problems reading pdf files ipad browser
reduce pdf file size ipad
reduce pdf file size on ipad
reduce pdf size for ipad
reduce pdf size ipad
