Peripheral Device Driver
This is a discussion on Peripheral Device Driver within the iPad Help forums, part of the Apple iPad Discussions category; I have tried to pair my iPad with my Dell PC and have received an error message about the Peripheral Device Driver is not installed. ...
Results 1 to 7 of 7
    13191
    Aug 2010
    Australia
    77
    Where do I find this file to download and install? Thanks
    iPad Guru
    30446
    12 times
    3,196
    Which Windows version are you using on the laptop?
    Windows Vista&7 should automatically install the necessary iPad drivers, when you connect the iPad to the laptop, so should XP 32-bit. Only XP 64-bit should give trouble.
    Another question: Through which means are you connecting the iPad: Bluetooth or USB?
    13191
    Aug 2010
    Australia
    77
    Thanks for taking the time to answer. I am using W7 and tryingnto connect through BT.
    I uninstalled and reinstalled the Widcomm BT software sent to me by Dell. No joy!
    Interestingly, I am also am able to pair my Wacom tablet.
    Yet, I have paired my mouse, phone, and printer to my computer, and my phone to my iPad.
    iPad Guru
    30446
    12 times
    3,196
    Pairing an iPad with Windows won't work. The iPad's bluetooth is fairly restricted and it can't be used for things, such as file transfer. In general, the iPad bluetooth can only be used for connecting a keyboard and headphones, pretty much everything else won't work.
    Unless you have another iOS device, then you could also use bluetooth to play games, share files, etc.
    7489
    132 times
    Jun 2010
    Sacramento, California
    14,940
    Quote Originally Posted by DontUnderstandMyIpad View Post
    In general, the iPad bluetooth can only be used for connection a keyboard and headphones, pretty much everything else won't work.
    Good to know ~
    What was the OP trying to use it for?
    Marie ~
    Forum Rules. Please Read.
    appleforums.net
    13191
    Aug 2010
    Australia
    77
    Quote Originally Posted by SweetPoison View Post
    Good to know ~
    To sync the iPad with my computer instead of using a USB cord. If it worked I could permanently have my iPad and computer paired.
    iPad Guru
    30446
    12 times
    3,196
    Quote Originally Posted by Luvntravln
    The iPad's bluetooth is restricted and syncing via Bluetooth is not among the things that are supported, you will have to do that by using the usb cable.
    Once a jailbreak comes out for iPad 2, you could use Wifi-Sync to sync the iPad via Wifi, or over 3g. This would let you keep the iPad always synchronized.
  1. Replies: 9
    Last Post: 01-17-2011, 12:48 AM
  2. Audi A1 Beat Driver Zooms Onto iPad
    By Maura in forum Apple iPad News
    Last Post: 10-01-2010, 09:51 AM
  3. Driver needed for camera connection kit?
    By texaslonghorn in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 08-20-2010, 01:31 AM
  4. iPad as a Peripheral?
    By ColinScatt in forum iPad Hacking
    Last Post: 05-04-2010, 12:23 PM
bluetooth peripheral device driver for ipad 2
bluetooth peripheral device driver ipad windows 7
bluetooth peripheral device for ipad
bluetooth peripheral device ipad
bluetooth peripheral driver for ipad
ipad bluetooth peripheral device driver
ipad peripheral devices
windows 7 (32 bit) bluetooth peripheral device driver for ipad
