Battery draines quicky after 10 percent left
This is a discussion on Battery draines quicky after 10 percent left within the iPad Help forums, part of the Apple iPad Discussions category; I have an ipad1 the battery works great until it reaches with 10 percent battery left. And it comes up with a warning with 10 ...
Results 1 to 4 of 4
    46512
    Texas
    I have an ipad1 the battery works great until it reaches with 10 percent battery left. And it comes up with a warning with 10 percent battery left and should charge. The problem is it drops quickly and it doesn't charge. I usually have to reconnect it to my CPU and when the screen comes back up plug it into the wall charger and then it is a slow process back to 100 percent. I have tried changing the cable wall charger plug. Any help would be greatly appreciate it.
    55594
    May 2011
    UK
    5
    I read an article that said charging a battery after it is fully depleted will shorten the life. It said to charge batteries when there is still a little bit of energy in it.
    12657
    4 times
    Aug 2010
    Area DM51
    669
    It's best not to let the battery drain too low if you can avoid it. Read this post for further information.
    Banned
    48444
    Wales
    667
    20% and I put mine on charge. I don't wait for the warning message!
    Jeff
  1. Replies: 4
    Last Post: 04-20-2011, 09:06 PM
  2. Replies: 1
    Last Post: 04-19-2011, 06:59 PM
  3. Over 80 percent of Fortune 100 now testing or using iPad
    By xune in forum User News Submissions
    Last Post: 01-31-2011, 11:23 AM
  4. average battery time left
    By alternative_ in forum iPad Hacking
    Last Post: 12-09-2010, 12:11 AM
  5. Replies: 3
    Last Post: 07-21-2010, 06:55 PM
how long does 10 percent battery ipad last
how long does 10 percent battery last
how long does 10 percent battery last on iphone
how long does 18 percent battery last on iphone
how long does 18 percent last on iphone
how long does 20 percent battery last on ipad
how long does the iphone battery last @ 20percent
how long will an ipad last with ten percent of battery
how much time can 20 percent on the ipad
how much time left for 18 percent of battery on ipad
how much will 10 percent battery on iphone last
ipad 20 percent battery left
