Results 1 to 6 of 6
    47928
    3 times
    Southern California
    278
    iPad Will Not Sync
    My First Gen iPad will not sync. It stayed at Step 1, backing up iPad for over three hours and would not continue. My iTunes is on a Windows PC running XP.
    I previously created a backup with no apparent problem and updated to OS 4.33. But then I noticed that none of my pdf files were in iBooks. They showed on iTunes so I tried to sync.
    Any help greatly appreciated.
    9323
    Jul 2010
    Southeast Wisconsin
    674
    Stuck in back-up can be rectified by rebooting the iPad with it plugged into the PC and iTunes up and running. (Hold the Home button and sleep/wake button simultaneously on the iPad until you get the message to slide). Slide the slider to boot the iPad. The spinner will appear and the iPad will shut down. Wait 30 seconds or so and turn the iPad back on. (Hold down the sleep/wake button until you see the Apple logo.) When the iPad restarts click on your iPad name in iTunes then click one of the tabs in iTunes (apps or movies) and click "Apply" rather than synch. This has worked for me twice in the past.
    Note: If the spinner spins for a long time during shut down hold the sleep/wake button down again and it should eventually shut down.
    Sent from my IPad
    624 times
    Dayton, WA
    13,315
    Quote Originally Posted by The Alternative View Post
    Interesting. I've never run into this problem, but it's good to know. The other possible solution I've heard of is to go into iTunes Preferences, the Devices tab, and delete the backup file.
    It is not necessary to hold the home button to get the power off slider. The sleep/wake/power button by itself will do just fine.
    Holding the power and home button at the same time is for a soft reset. When doing that you ignore the power off slider, and wait until you see the Apple logo. It then reboots. What more this does than a simple restart, I don't know, but it has fixed things a restart wont.
    47928
    3 times
    Southern California
    278
    Thanks for all the help. I finally got it to sync, but there is a new problem. Some apps did not show after sync. I noticed that some were not checked off on iTunes even though I had selected the option to automatically sync new apps.
    I generally add new apps directly from the iPad, not purchasing through iTunes and then syncing. I went back, checked apps and synced again.
    Now, when I go to the iPad, it shows a number of the apps need updating, even though I had previously updated them on the iPad.
    Did I miss a step? Are apps still not quite in sync?
    9323
    Jul 2010
    Southeast Wisconsin
    674
    Quote Originally Posted by singlestick View Post
    I think that if you update the apps in iTunes and synch again you should be okay.
    Sent from my IPad
    47928
    3 times
    Southern California
    278
    I think that this might have been the answer. I don't have an iPhone, so maybe there is a similar step for that device that everybody knows about.
    When I deleted and tried to reinstall a free app, I got the message, "You have already purchased this app. Check for available downloads" in iTunes. I think this is a pointlessly cryptic message.
    I normally purchase apps directly through the app store app on the iPad. I thought that selecting the option to transfer purchases to iTunes would take care of things when I connected to my PC.
    But I noticed an option in iTunes for apps, Check for updates." I selected this option, and let iTunes update before syncing again.
    This appears to have worked, although I am still showing a couple of apps that still show as requiring an update.
    This may help another user in the future. Note that I don't think that doing a reset accomplishes anything unless you have tried to update apps.
  1. How to sync Ipad with another Mac
    By olivertimm in forum iPad Help
    Last Post: 08-22-2010, 03:43 PM
  2. How do I sync my ipad to my mac when i originally sync'd it to a PC
    By RoaHokie in forum iPad General Discussions
    Last Post: 06-30-2010, 07:48 PM
  3. Sync from PC to iPad
    By mslammers in forum iPad Help
    Last Post: 06-29-2010, 11:46 AM
  4. Replies: 1
    Last Post: 06-16-2010, 09:20 AM
  5. Sync ipad with pc
    By 300cman in forum iPad General Discussions
    Last Post: 04-29-2010, 11:10 PM
1st gen ipad apps not syncing
first generation ipad wont connect to computer
first generation ipad wont sync
ipad 1 not syncing
ipad does not sync with ituned on step 3
ipad gen 1 not syncing
ipad not syncing
ipad will not sync
ipad will not synch
syncing ipad will not get past step 5
why are some movies not syncing with my ipad 1
why ipad will not synch with mac
