Hi
I have downloaded the photo app and sync my computer to transfer all my photos which has worked well. However, I cannot arrange the photos into albums, rename, delete etc.
What should I do or which app should I use.
thanks for any help
Hi
thanks for any help
The iPad photo app is very rudimentary and frankly your best bet is to arrange your photos into folders before you add them to iTunes.
I've tried a number of apps but none of them are that useful
Just hopeing that it will be seriously improved with the next iOS upgrade.
The iPad's native Photo app cannot create folders and it cannot delete photos that have been synchronised with your PC. To create folders this needs to be done on the PC and then a sync. Similarly, to delete photos that were sychronised with the PC, they need to be deleted from the PC first and then synchronised again. Photos that were not synchronised - say they were received by email - can be deleted in the Photos app.
Most members use a third-party app; these enable you to create folders/albums, delete photos and organise them any way you want.
Wish "most members" would recommend something good
Tried a couple, but they are long gone now.
Have a look in these threads...
photo album app?
Alternative photo app?
Thanks Tim. Downloading Photo Manager now.
Hope it's better than the last ones I tried. Funny there's no reviews though....
Thank you everyone for your help. I understand that if I had a mac and iphotos I could sort on the mac. It's a shame the iPad has limited functions at the moment.
