Problems with applications syncing and working
This is a discussion on Problems with applications syncing and working within the iPad Help forums, part of the Apple iPad Discussions category; Hi, new to the world of iPad and getting frustrated. Got an iPad as a present (yes, lucky me). It was bought in Singapore and ...
Hi, new to the world of iPad and getting frustrated. Got an iPad as a present (yes, lucky me). It was bought in Singapore and preloaded with a number of applications. Was presented with it a few days ago and in trying to sync with my current PC and iTunes have hit a few snags. Couldn't figure out how to get the apps from iPad to iTunes but most were free so reloaded the ones I wanted and then deleted the others off the iPad. I now find that I can't sync the current load of apps from iTunes to iPad - they show up on the PC iPad connection but not on the actual unit, if that makes sense. Also the majority of apps on the iPad don't work. I tap to start but I just get returned to the screen. Any and all help appreciated. Cheers
05-08-2010 07:00 AM
welcome on board I am in Brisbane
Frankly I would do a restore as I think the previous person registered the ipad in his or her name so as far as Apple is concerned you are not the owner To restore connect the ipad to Computer open itunes and once mounted select restore If you do not sync it will create a new account you then need to register via itunes set up the new account under your name and start over with Applications
Also the crashing sounds like a problem with memory on the ipad.You could also before you do all this hold down the home button and off button until the Apple logo shows this is a hard reset.
Also check that when the ipad is mounted select applications on ipad and tick the applications you wish to sync. Best of luck
Colin Brisbane
Originally Posted by
Suec292
It sounds like you got a pre-used unit, as there are no apps that ship with the iPad. It's possible that your iPad is already associated with another account or might have been jailbroken or something. I suggest starting over from scratch (wipe the iPad like it is brand new).
Note the below instructions will start you over like an iPad direct from the factory. Normally for people who are having synch problems I don't recommend this, but it sounds like your unit was tampered with before you got it, so this is the best way to start fresh.
The only thing that might make the below not work is if you have a fake iPad or a KIRF. To verify that you do not before starting, visit this site:
Apple - Support - iPad - Service + Repair
Type in your iPad's serial number (found on your iPad by going to Settings -> General -> About) and click submit.
It may not be registered, but if the Apple site says it is an iPad, you should be ok.
Here is how:
Preparation:
- Have your computer ready with iTunes up and running.
- Have your iPad synch cable plugged into your computer but NOT your iPad (yet)
- Make sure your iPad is at least at 20% battery, preferably higher
Steps:
- Sitting next to your computer, take your iPad (which should NOT be connected to your PC) and hold down the sleep button (on the top of the iPad) and the home button at the same time
- After about 10 seconds, the unit will power off (do not do anything when the "slide to power off" screen appears, just keep holding the buttons
- When the unit turns back on and you see the silver Apple appear on the screen, continue holding down the home button but release the sleep button and immediatly plug the iPad into your computer running iTunes
- You should see a symbol appear with a picture of a USB cable with an arrow pointing to the iTunes logo. iTunes will then say that it detected an iPad in recovery mode. Let iTunes restore the device. It will download a fresh copy of firmware, install it, and verify the SW.
NOTE: This may take a while, as iTunes needs to download about 500MB from the Apple server.
- After iTunes said that is successfully restored your device, you may get an error message saying the iPad isn't recognized and you're still at the screen with the USB cable and iTunes logo on the iPad. Don't sweat it. Unplug the iPad from the computer. Power off the iPad by holding the sleep button until you see the "slide to power off" - go ahead and slide to power off. Once it is shut down, push the sleep button again until it powers on.
- the iPad might come back to the familiar USB cable to iTunes logo. When it does, just plug it back into your computer and iTunes will activate the iPad.
- Pick your synching options (apps, music, movies, etc, etc) and have a blast!
Thanks Colin - I did exactly that - restored to factory settings then re-sync'd and it seems to be working fine now.
- You may not post replies
- You may not edit your posts
Forum Rules
By Steppenroth in forum iPad Apps
Last Post: 08-31-2011, 06:22 AM
By iDan in forum iWork Forum
Last Post: 08-19-2010, 12:58 AM
By Dallasfoto in forum iPad General Discussions
Last Post: 04-19-2010, 04:34 PM
By HungryWriter in forum iPad General Discussions
Last Post: 03-16-2010, 05:42 PM
application error and computer shuts down when sync photos
computer shuts down when syncing ipad
i got a problem with itunes app sync
ipad plugged into another account now apps dont work
ipad problems applications
ipad problems with apps
itunes shuts down after sync
laptop shuts down when syncing ipad photos
pc shuts down when syncing with itunes
problems with adding apps to the ipad
singapore itunes sync problem
troubleshooting apps on ipad
