Just used FaceTime on my iPad and noticed there's a small white flashing dot that shows up on the screen. It's really small and it's appearing on the very side of the screen.
Has anyone else experienced this or know what it could be?![]()
This is a discussion on Small White flashing dot on FaceTime screen? within the iPad Help forums, part of the Apple iPad Discussions category; Just used FaceTime on my iPad and noticed there's a small white flashing dot that shows up on the screen. It's really small and it's ...
I moved your post to the Help section, where I think it will receive better attention. I hope that is OK.
iPad Forum Moderator
Apologies, yes thats fine
I suspect this is not the issue - but have a look at the 'white dot' test on this link....
Buying an iPad 2? Check for these faults
Thanks, I will do the black screen test again this evening. They mention no cure to the problem, hopefully I don't have to swap this device for a "new" one again. Starting to lose all faith in apple...
Can you recall if it only is a problem with the FaceTime app? If it's just that app, then I can't see how it can be a pixel problem. If it occurs in all apps, then maybe - but since you mentioned just the FaceTime app, that's why I was sceptical about it being a 'dead' pixel on the screen.
I'm not to sure if it happens on any other apps as I only noticed this last night whilst using FaceTime. I will double check tonight.
Right so I just done the black screen test and can't see any flashing dots on it. So from that it only seems to be on the FaceTime app! Any ideas?
One thing I did notice was when in the dark and I turn my iPad downwards so the screen is facing the floor and I look at the 4 sides of each section of the screen I notice a small gap of light breaking through what seems the seal? Is this normal or is it light bleed?
I suspect that all screens bleed to some extent and the only issue is whether the problem worries you. If it does, take your iPad back and exchange it.
I'm puzzled, though, by your white dot problem - I've not heard anyone else mention this and, now that you've eliminated a possible dead pixel, it has to be a 'feature'!! Let's hope someone else knows...
Yea only seems to be FaceTime, no other apps suffer from this problem. Going in for my second exchange tomorrow...
