Home router problem
This is a discussion on Home router problem within the iPad Help forums, part of the Apple iPad Discussions category; My iPad has worked flawlessly with my home router since I got it six months ago but now, suddenly, every app says there is no ...
Results 1 to 8 of 8
    54773
    May 2011
    USA
    Home router problem
    My iPad has worked flawlessly with my home router since I got it six months ago but now, suddenly, every app says there is no internet connection -- even though it shows that it is connected to the router. Even more curious, my iPhone continues to connect to the internet through the same router. After I couldn't get a connection at home with my iPad, I went to Starbucks and had no problem connecting and going online via WiFi. Then when I got back home, iPhone works and iPad doesn't. Any ideas?
    iPad Enthusiast!
    50470
    May 2011
    USA
    77
    Have your called your ISP and told them of the problem? Also, most router manufacturers have a website for their brand where you can find help and sometimes even a Live Chat tech or phone number. Hope this helps.
    iPhone 4, iMac, iPad 2 WiFi, Zaggmate keyboard case, Jambox by Jawbone, Apple Camera Connection kit, Apple Magic Mouse, Apple wireless keyboard, Apple Airport Express
    20755
    8 times
    Nov 2010
    Michigan
    436
    There are a number of threads about this, you can check around. However, even though your phone works, you might try rebooting your router. That's worked for me when every thing else seemed "normal". It wouldn't hurt to restart you iPad too, if you haven't done that in a while.
    54773
    May 2011
    USA
    I just rebooted the router and I've restarted my iPad several times. I've renewed the lease, cleared everything in Safari -- everything and I still get the same message in every app, "no network detected." Should I totally reset and erase everything. I just made sure to backup everything on iTunes. Is it easy to restore everything?
    54311
    May 2011
    Costa Rica
    16
    you restart your iPad, but did you Resetted it?
    For doing so, you must press the On/Off button a few seconds to see a window appears.
    Most of the times this fix any application problem... like download problems from AppStore.
    20755
    8 times
    Nov 2010
    Michigan
    436
    Make sure you've got strong wifi signal (3 fan shaped bars) in the upper left where it says iPad.
    If you have a 3G model you can try switching to that.
    Take a look in Settings > General, make sure "Restrictions" is off
    28887
    3 times
    NH
    758
    look for a firmware update for your router.
    Ipod 32 GB
    Not everyone has to agree with your point of views, but at some point they need to accept Them!
    iPad Addict
    37720
    6 times
    Colonial Heights,Va
    1,395
    Quote Originally Posted by ipaddj View Post
    No need to go that far. You can delete the wifi network without a master Ipad reset.
    Settings , reset, reset network settings . It will delete the wifi only. Don't freak when your Ipad shuts off and restarts.
    then go into settings , general, network, wifi on, your Ipad should search/find your router
    If that doesn't work it's tor router since it works fine elsewhere.
    Support Our Troops!!
    This post was Tapatalk approved. Sent from my Inc
  1. Home button problem
    By Wbtt in forum iPad Help
    Last Post: 09-22-2011, 02:46 AM
  2. home sharing problem
    By samch in forum iPad OS
    Last Post: 07-04-2011, 02:37 PM
  3. Replies: 15
    Last Post: 06-12-2011, 04:45 PM
  4. Replies: 9
    Last Post: 04-03-2011, 07:29 AM
  5. Westell router problem
    By iceman in forum iPad Help
    Last Post: 06-03-2010, 08:33 AM
apple router issues
apple router problems
home router problems
ipad 2 router issues
ipad router issues
ipad router problem
ipad router problems
iphone router problem
router settings for app store
router working but now no internet on ipad
