SKYPE, no outgoing sound, iPAD Wireless only
This is a discussion on SKYPE, no outgoing sound, iPAD Wireless only within the iPad Help forums, part of the Apple iPad Discussions category; When doing the test call with Skype I can here the operator's voice (incoming) but not mine (outgoing). I cannot find any settings to address ...
Results 1 to 6 of 6
    54156
    May 2011
    Switzerland
    I cannot find any settings to address this!?
    116 times
    15,249
    Several members have had this problem and the 'cure' below seems to work (but also check you haven't got the Skype 'Mute' control activated!)
    54156
    May 2011
    Switzerland
    Solution 1 did not help however, solution 2 did!
    Thank you very much, Tim.
    152160
    Jan 2012
    London
    I have an iPad 2 with the new iOS and the latest version of Skype which has this issue - no outgoing audio. Neither of these solutions works, and it is not the Skype mute. Anyone have any more ideas?
    165671
    Feb 2012
    I am a new user and haven't found out how to ask a question yet, but I have the same problem with Skype and now Facebook. I have powered down and deleted the skype app and reinstalled. Both used to work fine. I don't have the mute button on.
    108678
    Oct 2011
    malaysia
    5
    I've been having this sound problem several times.. I missed my teacher's calls a lot and it kind of frustrating me. Sometimes i have to wait several hours in front of the ipad just to make to sure that i don't miss any of those calls ( and end up, not being called, hahaha ) But at the same time, i don't want to waste my time waiting..
    I think i've tried solution number one but nothing changed. I'm going to try solution number two. I'll let you know if it works.
    Thanks man..
    Melati
    Malaysia
  1. Change Display Name in OutGoing Email
    By naman919 in forum iPad General Discussions
    Last Post: 09-19-2012, 05:15 AM
  2. Replies: 15
    Last Post: 01-22-2012, 05:00 AM
  3. No Sound on Skype
    By amyberta in forum iPad Help
    Last Post: 05-06-2011, 10:24 AM
  4. Replies: 0
    Last Post: 11-19-2010, 12:32 AM
audiosettings for apple ipad for skype
ipad skype no outgoing sound
ipad skype no sound
ipad skype ses sorunu
ipad voice setting skype
no sound on skype ipad
nosounds on skype in ipad
problems with sound on skype for ipad
skpe no sound on ipad
skype ipad app no sound
skype ipad no sound
skype on ipad no sound
Tags for this Thread
