battery saving
This is a discussion on battery saving within the iPad Help forums, part of the Apple iPad Discussions category; Is there any way to get a blank scren when listening to audiobooks? I listened to an audiobook and got a battery low warning and ...
Results 1 to 4 of 4
Thread: battery saving
    42938
    birmingham uk
    13
    battery saving
    Is there any way to get a blank scren when listening to audiobooks? I listened to an audiobook and got a battery low warning and had to close down to recharge.
    The screen all the time reading was showing the book cover in full colour, or chapters in black and white.
    It would be usefull if the screen was blanked whilst listening, and return upon screentouch.
    Anybody have ideas on this please.
    elltell.
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    Is putting the iPad to sleep (pressing the power button), not good for you?
    Audiobooks will continue to play when the iPad is off. Then just slide to unlock again when / if you want to interact.
    You can turn the screen off as you suggest on a jailbroken device. The app "Screendimmer" does this, but it seems as if just turning off should be just what you wanted, no?
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b2 (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    42938
    birmingham uk
    13
    battery problem
    Thank you for your reply. Simple when you know how, I would not have done this on the assumption that I would be switching the ipad off.
    Prob solved
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    Quote Originally Posted by elltell
    Prob solved
    Great! A simple solution but a eureka moment none the less!
  1. 3g saving tip, and for those without 3g!
    By Serianni in forum iPad Help
    Last Post: 05-18-2011, 10:12 PM
  2. Saving PDF on iPad
    By gray_mouse in forum iPad General Discussions
    Last Post: 04-04-2011, 01:54 AM
  3. saving 3g time
    By jrowlings in forum iPad 2 Forum
    Last Post: 03-13-2011, 01:06 AM
  4. Battery Saving Google Search
    By iphoneFTWbro in forum iPad General Discussions
    Last Post: 11-29-2010, 08:29 PM
  5. Saving blobs
    By Matth3w in forum iPad Hacking
    Last Post: 06-17-2010, 08:17 PM
battery saver for apple ipad 16gb
battery saver i pad
battery saver on i pad 2
ipad battery audiobook
ipad saving battery
ipad1 5.1 low battery
saving battery on ipad
saving battery on ipad 1
saving battery on ipad 2
saving battery. ipad
savingipadbattery
