Volume button doesn't mute
This is a discussion on Volume button doesn't mute within the iPad Help forums, part of the Apple iPad Discussions category; Hi all. First post here. First iPad. Anyhow, just a quick question really. My ipad2 doesn't mute when the volume is turned right down. Is ...
Results 1 to 9 of 9
    53794
    May 2011
    Brighton
    8
    Hi all. First post here. First iPad. Anyhow, just a quick question really. My ipad2 doesn't mute when the volume is turned right down. Is this normal? I use the switch to lock the orientation and not as mute.
    116 times
    15,249
    There are a couple of issues here.
    (1) The mute control - be it the switch or multi-task bar control - only mutes system sounds - i.e. new email etc - it does not mute other audio - say music or videos
    (2) The volume control works separately for headphones and speaker. So, if you turn the volume all the way down for the headphones and then unplug them, the iPad 'remembers' the previously set speaker volume and uses that. If you want to turn the speakers down, you have to do that as a separate operation.
    53794
    May 2011
    Brighton
    8
    Thanks for the speedy response. My issue is that when I turn the volume control way down so no dots are present it still plays new mail, mail sent etc. sounds. I haven't tried headphones yet.
    116 times
    15,249
    Quote Originally Posted by BC1973 View Post
    But do you have Mute activated?
    116 times
    15,249
    Also, another thing to try - completely power the iPad down rather than simply putting to Sleep. This fixes a lot of unexplained 'problems'
    53794
    May 2011
    Brighton
    8
    How do you mean? I have the mute switch set to orientation lock. What I need to know is if it's 'normal' for the iPad to still play system sounds like sent mail when the volume is turned down full. I know I can mute everything by setting the toggle switch to mute in settings but I prefer to have the orientation locked.
    iPad Guru
    30446
    11 times
    3,197
    That behavior is normal, because alerts are independent of the system volume. So even if you have the volume turned down to zero, will incoming mails, etc. make a sound. It is possible to change this, so that alerts also depent on the current set volume. This can be done under Settings->General->Sounds->Change with Buttons: On
    What Tim was referring too is, that even when you have the side-switch set to orientation lock, you can mute the device by pressing the homebutton twice (to open the multitaskbar), scroll left and select the volume key on the left.
    53794
    May 2011
    Brighton
    8
    Wonderful. That's exactly what I wanted to know. Thanks guys.
    55153
    May 2011
    i also noticed in the help guide if you hold the volume button in the middle for 2 seconds that it will mute that way.
  1. Mute button not working?
    By DontUnderstandMyIpad in forum iPad General Discussions
    Last Post: 02-05-2011, 01:57 AM
  2. Mute button does not work.
    By outbackyak in forum iPad Help
    Last Post: 01-16-2011, 01:54 AM
  3. Mute button not working
    By Benm1020 in forum iPad General Discussions
    Last Post: 12-29-2010, 10:51 AM
  4. Mute button not working
    Last Post: 12-29-2010, 07:51 AM
  5. MUTE button & Volume buttons
    By donka in forum iPad OS
    Last Post: 12-08-2010, 06:05 AM
down volume mutes headphones ipad
how to mute ipad 2
how to quickly mute ipad system sounds
how to turn the mail volume down on an ipad
ipad holding volume button mute
ipad mute button doesn't work
ipad mute doesn't work
mute on ipad 2 doesn't work
mute on ipad doesn't work
my ipad2 is on mute but it will still play volume
sound control on ipad not muting
volume works mute doesn't
Tags for this Thread
