Power Up Problems
This is a discussion on Power Up Problems within the iPad Help forums, part of the Apple iPad Discussions category; Hello, New user here. Anyone else having problems powering up their unit after it's been shut down? Mine does power up but often I get ...
Results 1 to 5 of 5
    3805
    May 2010
    Boston
    Power Up Problems
    Hello,
    New user here. Anyone else having problems powering up their unit after it's been shut down? Mine does power up but often I get the round circle going for a while then it's shuts down. On a second try I get the Apple logo and it goes on properly from there. Using a new 32GB with 3G.
    Any help would be appreciated.
    iPad Master!
    2592
    3 times
    Apr 2010
    NH
    517
    Take this for what it's worth, but my iPad powered up fine until I turned the brightness level down to minimum in settings. After that it took forever to display the apple logo and start up. when I restored brightness to about 25% had no further difficulty. Not sure this applies to you but maybe worth a thought.
    9499
    Jul 2010
    Quote Originally Posted by jrd042 View Post
    Hello,
    Have you reached any resolution for this problem? Mine does the same thing but very intermittently - perhaps once every two or three weeks. I have a feeling that this issue is caused by a misbehaving app but I have no hard evidence.
    3805
    May 2010
    Boston
    It has been very random so I've just decided to live with it. Other than that I still love it, no other problems since purchase.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    If you bought it brand new from Apple (store or web site) or BestBuy, there is no reason for you to just "live with it". Its not supposed to work that way. Mine doesn't do that and yours shouldn't either. You paid $729.00 (I assume) and there should be no problems. Take it back to where you bought it and exchange it.
  1. WIFI Problems
    By imaxipad in forum iPad General Discussions
    Last Post: 09-08-2010, 05:37 AM
  2. Problems with glare
    By raylock in forum iPad General Discussions
    Last Post: 05-05-2010, 11:13 AM
  3. An app to help you with your problems.
    By markerrett in forum iPad Apps
    Last Post: 05-05-2010, 05:20 AM
  4. Power Tests
    By Seadog in forum iPad General Discussions
    Last Post: 04-06-2010, 10:25 PM
  5. Different Power adapters?
    By raylock in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-31-2010, 09:10 AM
how to power up an ipad
ipad 1 no power
ipad 1 no power solution
ipad no power
ipad problem no power
ipad will not power on
ipad will not power up
no power ipad
no power on ipad
no power to ipad
problem powering up ipad
solution to ipad power problem
