I can't find my way round this site . I need help setting up the ipad- is this where to ask?![]()
This is a discussion on Please help 'Oldlady' within the iPad Help forums, part of the Apple iPad Discussions category; I can't find my way round this site . I need help setting up the ipad- is this where to ask?...
Absolutely - I saw your other posts about the 5000 emails, so I'm assuming you've initialised your iPad and there are some other problems. Let us know what they are and we'll try and help. I've moved your post to the Help section as I think it will receive better attention there. Don't hesitate to get back with the problems you are facing - Tim
Another prob. Downloaded BBC iplayer app .shows on online screen but nothing on here ,
Sorry - but we need a bit more information.
You've downloaded the BBC iPlayer app to your iPad and I'm guessing you mean that you can see the iPlayer icon on your home screen.
What happens then if you press the iPlayer icon - does the iPlayer app 'open up' and eventually (you may have to wait a few seconds) display some graphics of some of the programs that you can watch. Of course, the iPad has to be on-line (connected to the Internet) for this to work.
Send us some more details and we'll try to help.
We Arne here to help you came to the right place
Cheers Colin,
Brisbane Australia
_____________________________
iPad User Guide
Forum Rules. Please Read.
Hacking Section Rules
No I have no app. On pad but it shows on the screen in iTunes and says it is 4+ mb.
OK - that's no problem. Is there a button - to the left of the screen - which says 'Free'? Just touch that, and then you'll be asked if you want to install it - hit 'Install' and the iPlayer app will automatically download and install itself on your iPad. That takes about a minute or so. You'll be asked for your iTunes password - I'm assuming you're doing this from your iPad - and then the download will start. The screen will change to your iPad Home screen and a dim icon of the iPlayer app will appear on the screen and initially it will say 'Waiting' then it will say 'Downloading', then it will say 'Installing' and, when that's finished, you're good to go. Touch the iPlayer app and it should open up and you'll see all the TV programs that you want to watch.
Again, get back to us if there's a problem - we love hearing from you...
Scotland - wet and windy today
Done it! Thanks againOriginally Posted by Tim SPRACKLEN
OL
