Most work fine just have trouble with select few. It has all just started lately. Any suggestions?
This is a discussion on Wont load certain sites? within the iPad Help forums, part of the Apple iPad Discussions category; Most work fine just have trouble with select few. It has all just started lately. Any suggestions?...
It just loads about half way and then stops. Then a couple min later a message appears saying can't connect to server. But works fine on a pc. So it's not the site. Cleared cookies. And router seems good. Aim somewhat of a novice with this stuff
I use the safari app if that makes a difference
The best way forward is to start with the simple stuff first. Try powering the iPad off completely - i.e. not just putting it to Sleep - by pressing and holding the Power button until the slider control appears. Accept the offer to switch off and then, when the iPad has completely powered down (blank screen), press and hold the Power button again until the white Apple logo appears and then wait for it to power back up. This simple procedure cures a whole load of problems and even Apple recommend you do this at least once a week.
I've tried powering off. That's not it.the message says. Cannot open page
Safari could not open
The page because server
Stopped responding
But the iPad works fine on other sites and their site is not down as It loads fine from my pc.
Continuing with the easy stuff
Settings->Safari->Delete Cache&Cookies&History
Tried that too. Still same problem
That website loads without trouble on an iPad 1.Originally Posted by Tmzek
Have you installed the newest iOS firmware? Or rather, which version are you currently using?
And have you restarted Safari?
It can be done as follows:
-double tap the home button, to enter the multitasking bar
-press onto the safari app, until it starts wiggling
-press on the red circle
