Safari issues
This is a discussion on Safari issues within the iPad Help forums, part of the Apple iPad Discussions category; Hi guys, I have been having the issue with safari that it becomes unresponsive and times out (server can't be found) and does not load ...
Results 1 to 5 of 5
Thread: Safari issues
    51184
    May 2011
    Tamborine
    Safari issues
    Hi guys, I have been having the issue with safari that it becomes unresponsive and times out (server can't be found) and does not load web pages. It does it a lot and makes browsing the web painful as I have to wait for it to time out before it kicks into gear. It happens on a host of different routers but only with safari, if I go to the app store or another Internet based app there is no issues.
    Any ideas? I'm up to date on all firmware so I have no idea.
    116 times
    15,249
    51184
    May 2011
    Tamborine
    Thanks for the reply however that does not work at all. I have read that this is a common issue and that apple was meant to have fixed it in a patch however it still does it. Any other ideas?
    116 times
    15,249
    Quote Originally Posted by Maximushaydos View Post
    OK - I'm sorry about that. I have no similar problems at all, so not sure what the problem is. Hopefully someone else in the Forum will have a better idea. Again, sorry I was unable to help with this problem.
    iPad Guru
    30446
    11 times
    3,197
    Restarting Safari does solve some temporary problems with the app, but it still leaves Safari's cache untouched.
    You might want to clean Safari completely, that should help. This can be done under:
    Settings->Safari->Clean Cache/Cookies/History
    Note that this will delete all history of websites you have ever browsed and removes all saved login information. Bookmarks however, are not deleted.
    This should make Safari run at normal speed again.
  1. safari and nook app issues with bn.com
    By cpurdom in forum iPad Help
    Last Post: 01-12-2012, 12:22 PM
  2. VGA TV issues
    By shanshuprophecy in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-20-2011, 05:33 AM
  3. Safari Issues
    By MDLR in forum iPad Help
    Last Post: 12-18-2010, 06:46 PM
  4. 4.2 Safari Issues
    By jonat in forum iPad General Discussions
    Last Post: 11-22-2010, 10:09 PM
  5. Wi fi issues
    By Imspartacus in forum iPad Help
    Last Post: 08-15-2010, 01:23 PM
ipad page timeout on safari
ipad safari cannot find server
ipad safari timeout
ipad safari times out
safari can't find server ipad
safari can't find the server ipad
safari cannot find server on ipad
safari time out error on ipad
safari timeout ipad
safari times out
safari times out ipad
safari times out on ipad
