Help Ipad Wifi problem after upgrade from 3.2.1 to 4.2.1
This is a discussion on Help Ipad Wifi problem after upgrade from 3.2.1 to 4.2.1 within the iPad Help forums, part of the Apple iPad Discussions category; Hi everybody Need your help. I've upgraded my ipad ios 3.2.1 to 4.2.1 everything looked fine but when i turned on my wifi and ran ...
Results 1 to 2 of 2
    51139
    May 2011
    bacolod
    Hi everybody
    Need your help. I've upgraded my ipad ios 3.2.1 to 4.2.1 everything looked fine but when i turned on my wifi and ran safari it alerted me with "Cannot Open Page Safari cannot open the page because it is not connected to the Internet" so i asked a tenant of ours if his wifi connection was working (he's using a laptop) he said it was still OK, so I went to a mall and tried my ipad and it worked fine there then i went to a caffee it still worked fine. So i thought maybe my ipad just needed some air but when i got home got connected then I got the same Alert again
    Has anyone had the same problem???
    Please help
    119 times
    15,248
    One of our moderator suggested this..
    This has resolved many issues and worth a try.
    __________________
    Cheers
    Col
    col.bris, Brisbane Australia
    Forum Rules. Please Read.
  1. WiFi dropping out after 4.3 upgrade
    By Billee in forum iPad OS
    Last Post: 06-17-2011, 06:00 AM
  2. OS 4.2 Upgrade Problem
    By jkoh in forum iPad OS
    Last Post: 03-08-2011, 03:40 AM
  3. OS 4.2 upgrade problem
    By Jetnut57 in forum iPad OS
    Last Post: 12-18-2010, 01:20 PM
  4. Wifi freezes after 4.2.1 upgrade
    By iduc in forum iPad OS
    Last Post: 12-02-2010, 09:30 PM
  5. Problem with the photo app after upgrade
    By Hansg in forum iPad Help
    Last Post: 07-25-2010, 04:25 PM
after upgrade iphone 3 to 4.2 wifi not working
fix wifi problems in 3g 4.2.1
how to fix iphone or ipad wifi connectivity issues after upgrading to ios 4.2.1
iphone 3g 4.2.1 wifi not connecting
iphone 4.2.1 wi-fi drop
iphone 4.2.1 wifi fix
iphone wifi fix 4.2.1
iphone wifi not working after ios 4.2 update
