Losing Wifi connection
This is a discussion on Losing Wifi connection within the iPad Help forums, part of the Apple iPad Discussions category; My IPad kicks my wifi connection out. This doesn't happen on my IPhone ever. Does anyone have this issue?...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    51125
    May 2011
    Calgary
    116 times
    15,249
    Two possible solutions.
    First, the easy one....
    Try switching the iPad completely off and then on again - it's known to fix a whole load of unexplained problems and even Apple recommend you do this about once a week. Press and hold the Power button until the slider control appears, accept the offer to switch off, wait until the screen goes completely blank, then switch on again by pressing and holding the Power button until the white Apple logo appears. It then takes a few seconds for the iPad to power up and the orientation control is disabled during this time so don't worry.
    See if this fixes the problem. If it doesn't one of our other moderators has suggested this...
    This has resolved many issues and worth a try.
    __________________
    Cheers
    Col
    col.bris, Brisbane Australia
    Forum Rules. Please Read.
    Hope one of these works for you
    39645
    Medford, OR
    155
    I don't know whether this is what you're experiencing, but my wifi just stops working occasionally. The symbol is still up in the corner, but no data is transferred. (other wifi devices on the network continue to work). I've found that turning the iPad's wifi off and back on restores the data flow. I've only had this happen on my home network.
    Lewis
    42577
    UNITED STATES
    105
    Quote Originally Posted by DeniseS
    I have IPad 1. No problems here.
    Sent from my iPad 32gb WIFI 3G 1st generation.
    iPad Enthusiast!
    51040
    May 2011
    Perth
    36
    If you keep on disconnecting from your wifi then there's something wrong with your wifi connection. I been using apple gadgets for the past years and never encountered wifi disconnection not unless there's something wrong with my wifi modem.
    Sent from my iPad
    42577
    UNITED STATES
    105
    Quote Originally Posted by iBealicious
    Sent from my iPad
    True there have times when I had to reboot my computer router.
    53260
    May 2011
    New guy here. New to iPad 2 as well. I'm running 4.3.3 as my operation system and I'm having the standard issue of the iPad losing wifi on my home network. I haven't ventured out of the house yet to see if it stays connected to other networks.
    It really seems like whenever it goes into standby mode the connection is lost.
    I've gone through the steps of powering down the iPad and also resetting all my network connections.
    I read a thread that apple wasn't too concerned about this because it wasn't a big problem. By reading the threads, I think it's a bigger problem than what they think. It would be nice if there was an easy fix.
    Anyone out there know of anything else I can do? I would really appreciate it.
    Thanks,
    Jono
    Colorado
    iPad Addict
    37720
    6 times
    Colonial Heights,Va
    1,395
    Quote Originally Posted by iBealicious View Post
    Sent from my iPad
    Mine does it away from home and has no set pattern. Sometimes it does it every few minutes, sometimes not all day, sometimes in the middle of a download/upload.
    Mine showed up when I updated to 4.3.1 and my wife's on 4.2 does not have the problem.
    When it happens the lights on my wifi router and modem flash for about 5-10 seconds like data is moving at home.
    I've tried all the solutions I've seen on this forum to no avail.
    When I go to settings the iPad shows it's connected to the network but the connecting icon above it is spinning like it's trying to connect to a network
    Support Our Troops!
    This post was Tapatalk approved
    29345
    49 times
    Penarth, Wales, UK
    1,935
    There are a fair few threads regarding iPad wifi drop out.
    The problem has to be backwards engineered if a solution is to be found. Which I don't know how to perfectly do. But I do have a theory.....
    I do know the only constant in all these complaints is the iPad. Ipad hardwares are the same for every single model. Even the various versions of the iOS don't differ in this respect. So the different item here, the 'spanner in the works', must be the wifi router of the user. this is the only item that changes from user to user and why there's issues.
    I've always had perfect wifi reception likely, but in work it can sometimes be dodgy at best. Same for all other fellow employees with their devices. We know this is a wifi router issues.
    Don't assume that your router is flawless just because it works on other devices. Or just because it's yours
    Apple can't cater perfectly for making a perfect wifi connection with every router. Each and every router follow standards, but there is no set 'must', so components in each manufacturer's routers differ, meaning Apple can only please most of the people most of the time with their divice's wifi equipment. You've either got the right router or you haven't. My last 'cheaper' router was great for my iPod touch, but iffy with my smart phone. I now have a new connection and router and all works perfect. Put my old router back in the mix and it's dodgy again. Try various router security configurations
    That's my theory anyway
    iPF Expert
    33508
    108 times
    Feb 2011
    Somerset-UK
    7,873
    Reading threads since coming on here, the trend has been the router, most of the time, I personally haven't had problems, maybe because it's a BT HOME HUB but I agree with you.
    from Somerset UK on my iPad using IPF app
    IPad 3 32GB wifi, 2x iphone 4, iPhone 3GS 32GB , ipad 1 32GB ,2x iPod touch 2G, BT keyboard
    All for One and One for All!!!
    From Somerset UK
  1. Replies: 50
    Last Post: 10-12-2012, 10:42 PM
  2. Losing my network connection
    By Snookman in forum iPad Help
    Last Post: 04-13-2011, 04:40 AM
  3. Always use 3G, even with Wifi connection
    By DontUnderstandMyIpad in forum iPad General Discussions
    Last Post: 01-23-2011, 12:15 AM
  4. Replies: 3
  5. Keep losing wifi connection
    By Dpeach in forum iPad Carriers
    Last Post: 06-29-2010, 06:28 AM
ipad goes off wifi
ipad keeps losing wifi connection
ipad looses wifi connection
ipad loses wifi connection
ipad losing wifi connection
ipad losing wifi connection fix
ipad wifi goes in and out
my ipad keeps losing wifi connection
my smart tv loses wifi
why does ipad lose wifi connection
why does my ipad keep losing wifi connection
wifi goes in and out on ipad
