Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Kaykaykay
Thread: Notes Problem on iPad
    51038
    May 2011
    Question Notes Problem on iPad
    I recently updated my iPad to v4.3.2 . I now appear to have lost some entries I had made using the Notes function. I do have some Notes showing on the iPad however these are notes that I previously made on my iPhone that I sync on the same laptop as my iPad. I've lost some important information, can anyone help?
    46451
    Berkshire, UK
    17
    Do you synchronise your email, calendar, etc on your iPad with Gmail by any chance? I had a similar problem the other day and the notes disappeared from my iPad but thankfully were saved on my notes in Gmail. I was able to access them by connecting to my Gmail account from an internet explorer and there they we! Good luck, I hope that is the case, it is a nightmare to lose valuable information :-(
    51038
    May 2011
    Thanks for the tip.... My e-mail is sync'd to AOL and there are some Notes files on my e-mail page that I hadn't noticed were there before. These Notes are still also showing on my iPad however there are still some original Notes that I made that are not accessible from my iPad or from my e-mail.
    624 times
    Dayton, WA
    13,315
    First: go into iTunes, Preferences, the Devices tab and turn off auto syncing. This will keep iTunes from overwriting your last backup, just in case it's got your notes in it.
    Before we go into backups though, lest check another possibility.
    Connect your iPad to your computer, open iTunes, and select your iPad from the list of Devices. Now choose the Info tab at the top.
    Scroll down until you can see where it offers you the ability to sync notes. Is it selected? If so, you're probably out of luck.
    Select it, and note what app, or apps, it says it can sync your notes with. Now deselect it and go to those apps to see if your missing notes are there. If they are, go ahead and turn the sync back on and do the sync.
    The only other possibility is the backup. If you have not backed up (synced) the iPad since loosing the notes they may be in the backup file. Unfortunately the only way to find out is to restore from the backup.
    Open Preferences in iTunes and go to the Devices tab. Look at the date of the backup for your iPad and see if it is before your update. If so, you've got a good shot at getting the notes back.
    If you choose to restore from the backup, you will lose all other documents you've updated or added since the backup. So save or transfer them somewhere safe first. Be thorough. You may also loose you place in games, system settings you've made, pictures in the camera role, imported, or saved pics, and other adjustments.
    When you are sure you've not going to lose anything important, go ahead and right click on the iPad and choose Restore from Backup.
    It works, or it doesn't.
    163560
    Feb 2012
    United State
    I was recording in my notes from iPhone and had to manually correct a word and the copy paste bar appeared and I tried touching away from the bar but the phone pasted the last item I copied. Did I lose all that information for good? Would there be away I could undo that.
    624 times
    Dayton, WA
    13,315
    Notes does not have an undo. sorry.
    iPad Wizard
    49745
    384 times
    6,683
    I had a set of notes disappear recently from the native app, even though all my notes had synched correctly up till then. I noticed the app was acting funny (I'd try saving and it would randomly save or not). I reset and restarted, but I no longer trust the native app. I'm using Evernote, which I already had, instead.
    twerppoet likes this.
    283959
    Mar 2013
    some time ago, one of my notes duplicated itself so i deleted one of it, but in the end both copies were deleted simultaneously.
    this time, the same problem happened again, so i copy the note and paste it on a new one before deleting the duplicated copies.
    however, after i did that, the app crashed and no matter how many times i try, every time i open the app, it shows a blank note and crashes within 1second, and returned me to the home screen.
    i tried rebooting my ipad several times already, and even let the battery drained itself but the note app still crashes..
    does anyone has any idea how to fix it?
    thanks a lot!!
  1. Ipad for Taking Notes
    By edseo in forum iPad General Discussions
    Last Post: 01-16-2013, 06:45 PM
  2. Replies: 4
    Last Post: 05-04-2011, 10:25 AM
  3. How to get my Notes out of iPad without using iTunes?
    By jimjxr in forum iPad General Discussions
    Last Post: 01-22-2011, 03:40 AM
  4. Sync iPad with MS One Notes
    By rwsjreynolds in forum iPad General Discussions
    Last Post: 09-26-2010, 04:36 PM
  5. Replies: 2
    Last Post: 09-13-2010, 01:05 PM
ipad notes missing
ipad notes not saving
ipad notes not working
loosing saved notes on ipad
lost notes on ipad
missing notes on ipad
notes missing from ipad
notes not working on ipad
notes on ipad missing
notes on ipad not working
where did my ipad notes go
where did my notes go on my ipad
