Audio Out Problem
This is a discussion on Audio Out Problem within the iPad Help forums, part of the Apple iPad Discussions category; Jacking my Home Theatre to my iPad stopped working recently. There is sound from the iPad speakers but when I plug in the jack, everything ...
Results 1 to 4 of 4
    46770
    Brazil
    Audio Out Problem
    Jacking my Home Theatre to my iPad stopped working recently. There is sound from the iPad speakers but when I plug in the jack, everything goes mute. First time this happened I did a 'slide to shutdown' and it worked. But now even that isn't solving the problem. Any suggestions please?
    iPad Guru
    30446
    11 times
    3,197
    Quote Originally Posted by SCBrazil
    Have you raised the volume after plugging in the jack? The ipad's internal speakers and the headphone jack have different volume settings, so you can have one muted, while the other is blasting at full power.
    The other thing to check is, whether the jack is fully inserted. On the iPad 2, it can take a bit of a force to have it inserted all the way.
    If this does not solve the problem, than maybe your home theatre setup is set to use a different input than the headphone jack.
    116 times
    15,249
    Quote Originally Posted by SCBrazil View Post
    OK - this is probably not going to work, but we've had several members with this problem. However, since you've been using the headphone jack for a while it's probably not going to help you but.....just in case......
    The headphone jack/socket in the iPad is a very tight fit and it really has to be pushed *very* firmly home to seat properly. We've had several members who have reported the exact same problem as you and found it was simply that they had not pushed the headphone plug in firmly enough. It's particularly a problem, too, if you have certain protective cases on the iPad where the cut-out for the headphone socket can be slightly misaligned, causing the plug moulding to catch on the edge of the case material, thus preventing it seating properly.
    As I said, it probably won't help - but....hoping...
    46770
    Brazil
    Option Nș 1. So simple - turn the volume up. This had been driving me crazy for weeks. Thanks very much for your time. I feel a little stupid now!
  1. Audio Problem for some apps
    By rohlrogge in forum iPad Help
    Last Post: 09-26-2011, 10:49 AM
  2. Stream audio
    By athleticdept in forum iPad Help
    Last Post: 07-30-2011, 07:49 AM
  3. iPAD2 Real Racing HD2 via HDMI Audio problem
    By Katts89 in forum iPad 2 Forum
    Last Post: 04-24-2011, 01:19 PM
  4. iPad headphone audio v dock audio; is there a difference?
    By Pagliacci in forum iPad General Discussions
    Last Post: 04-09-2011, 09:26 AM
  5. Will Skyfire stream audio from flash audio player?
    By wahoowad in forum iPad General Discussions
    Last Post: 04-03-2011, 03:54 PM
ipad 2 audio out issue
ipad 2 audio out problems
ipad audio out
ipad audio out not working
ipad audio out problem
ipad audio out wont work
ipad audio output issues
ipad audio output problem
ipad headphone jack isn't working
ipad stereo output not working
my ipad mini headphone jack isn't working
stereo problem
