Stream audio
This is a discussion on Stream audio within the iPad Help forums, part of the Apple iPad Discussions category; Does anyone know how to set up the iPad to stream audio? I want to listen to a conference call on the iPad, the browser ...
Results 1 to 3 of 3
Thread: Stream audio
    35396
    Feb 2011
    5
    Stream audio
    Does anyone know how to set up the iPad to stream audio? I want to listen to a conference call on the iPad, the browser is safari, but when the audio begins streaming an audio application called VLC launches. This opens up an audio player, but the sound never begins, and there doesn't appear to be a "start" button.
    35396
    Feb 2011
    5
    Still having the same problem. Does anyone have a solution?
    116 times
    15,249
    Just a thought - the iPad has independent volume settings for headphones and loudspeaker. If you're trying to listen to the conference call on a headset but had previously had the volume set for loudspeaker, you'll need to reset it for the headset.
    Another possibility - some apps 'misinterpret' the mute button (which should only be to suppress system sounds) and use it to suppress all audio. Check the Mute function is not activated.
  1. TV Stream On IPAD
    By sshoaib in forum iPad General Discussions
    Last Post: 01-13-2013, 01:27 AM
  2. Stream directly from NAS
    By Norm01 in forum iPad General Discussions
    Last Post: 07-26-2011, 02:17 PM
  3. iPad headphone audio v dock audio; is there a difference?
    By Pagliacci in forum iPad General Discussions
    Last Post: 04-09-2011, 09:26 AM
  4. Will Skyfire stream audio from flash audio player?
    By wahoowad in forum iPad General Discussions
    Last Post: 04-03-2011, 03:54 PM
  5. Can Logmein Ignition Stream Flash Audio?
    By yxb in forum iPad Apps
    Last Post: 09-02-2010, 01:47 AM
audio streamipad
flash audio player for ipad
how to listen to flash audio on ipad
how to stream audio on ipad
how to stream audio to ipad
logmein audio streaming
logmein ignition stream audio
setting to stream ipad audio
stream audio from ipad
streaming audio player for ipad
