iPad Bluetooth / Motorola Wireless Keyboard help
This is a discussion on iPad Bluetooth / Motorola Wireless Keyboard help within the iPad Help forums, part of the Apple iPad Discussions category; Hi guys, Newbie here. My iPad 1 will not connect to the new motorola bluetooth keyboard. It finds the keyboard, but when I hit pair ...
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Tim SPRACKLEN
Thread: iPad Bluetooth / Motorola Wireless Keyboard help
    50590
    May 2011
    Hi guys,
    Newbie here. My iPad 1 will not connect to the new motorola bluetooth keyboard. It finds the keyboard, but when I hit pair a pop up box appears and dissapears within a second. It talks about entering a passkey (1875 I think) into the keyboard, but it goes to quick. Then the message that pair was unsuccessful.
    According to my research, the Keyboard supports HID, and motorola says it should work.
    1. Can I manually change the bluetooth password on my iPad?
    2. Anyone have any work arounds for this issue?
    3. Is there an app that could help me?
    My iPad 1 is running 4.2.1 and works with other Motorola stereo headsets. S9HD to be specific.
    I have factory reset the keyboard and still nothing.
    Thanks in advance for your help,
    Bryan
    116 times
    15,249
    Quote Originally Posted by anytimeuwnt View Post
    Hi guys,
    Bryan
    I don't have this particular Bluetooth keyboard but I have a similar one but have not experienced this problem. Indeed, I haven't seen other members report problems in pairing a Bluetooth keyboard. On my particular keyboard the default pass code was '0000' though, so I wondered where the number you were using comes from. I'm assumed too that you've tried the power-off, power-on reset on the iPad (you mention you've reset the keyboard but resetting the iPad too might help).
    Hopefully other members with this particular keyboard will be able to report on their experiences.
    TVos likes this.
    58539
    May 2011
    If you are using the new motorola bt keyboard, to pair with the iPad, hold the V A and R keys on the keyboard when powering up the keyboard. (as mentioned in the keyboard guide)
    Pair the keyboard using your iPad. Then you'll get a prompt to enter in a 4 digit passcode and enter on the keyboard. (it wont flash by like before) Presto!
    177845
    Mar 2012
    Washington State
    7
    Quote Originally Posted by Nether View Post
    I just wanted to say, I just got the New IPad (Ipad 3) and was having the same problem with my Motorola bluetooth keyboard. I tried your suggestion and it worked right away. THANK YOU!!
    186932
    Apr 2012
    USA
    Thank you for your post. I was trying forever to connect my motorola bt keyboard and holding down the "v-a-r" keys as per the manual, but it was only by shutting down and restarting my pod that it was then able to connect. thanks for the suggestion!!!
    202867
    May 2012
    yay!!!! i'm posting this using my Motorola keyboard. thank you for the help. this forum is my saving grace!!!! love ipad
    252070
    Oct 2012
    OK now I have the keyboard working, is there a key command to refresh the page please ??
    There are no function keys on it so I can't use F5...
    thanks
    265687
    Dec 2012
    San Francisco
    I was so amazed this worked with my iPad 4th generation I had to register and let you know! Awesome, thank you!
    271938
    Jan 2013
    Colorado
    This also worked for me. I bought the keyboard for an Android Xoom tablet a couple years ago and it worked out of the box, but the iPad gen4 exhibited the same symptoms mentioned by the first posting. After holding the V-A-R keys on a power-up the key/PIN prompt on the ipad remained persistent and I was able to enter it on the keyboard and connect. Thank you!
  1. Replies: 10
    Last Post: 03-18-2011, 02:12 PM
  2. Apple's Wireless Keyboard vs. Matias Wireless Folding Keyboard
    By WannaBeMac in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-23-2011, 08:36 PM
  3. Will the Apple wireless keyboard work w a bluetooth laptop?
    By Darkrider in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 09-13-2010, 12:12 PM
  4. Apple Wireless Bluetooth Keyboard
    By terrclymac in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-05-2010, 01:26 PM
  5. iPad dock keyboard vs bluetooth keyboard
    By Finnedog in forum iPad General Discussions
    Last Post: 03-29-2010, 08:58 AM
how to pair motorola bluetooth keyboard with ipad
how to pair motorola wireless keyboard
ipad motorola bluetooth keyboard
motorola bluetooth keyboard and ipad
motorola bluetooth keyboard ipad
motorola bluetooth keyboard iphone
motorola bluetooth keyboard pairing ipad
motorola bluetooth keyboard pairing with ipad
motorola wireless keyboard pairing
pair motorola keyboard with ipad
pairing motorola bluetooth keyboard with ipad
