Question regarding auto word suggestions
This is a discussion on Question regarding auto word suggestions within the iPad Help forums, part of the Apple iPad Discussions category; I noticed that when I type, suggested words appear. Sometimes they make no sense. Is there a way to edit these suggested words? Often, whatever ...
Results 1 to 3 of 3
    45419
    Tinley Park, IL
    14
    I noticed that when I type, suggested words appear. Sometimes they make no sense. Is there a way to edit these suggested words? Often, whatever I type gets replaced by these suggestions and I don't notice that what I type was replaced. Thanks.
    iPad Guru
    30446
    11 times
    3,197
    The autosuggestions are not great.
    You can only have them on, or off. This can be done under Settings->General->Keyboard. It is not possible to have it only show suggestions, but not autocorrect. For that you would need to jb.
    37956
    UK
    74
    If you tap the suggested word that appears in blue it leaves the spelling you typed alone, this isn't always great however as I don't look at the typed letters when typing and look at the keyboard instead. It would be better if it learned as you typed and didn't suggest the whacky words it comes up with from time to time.
    It would be nice if the iPad gave a visual or audio indication when it decides your spelling isn't correct, a chime or a flash of the keyboard colour for instance, to notify you it's going to change the text you've entered.
  1. Spelling Auto-correct Question
    By Munky in forum iPad OS
    Last Post: 10-09-2012, 02:20 AM
  2. Replies: 4
    Last Post: 03-06-2011, 01:53 AM
  3. Another word processing question
    By Rbutts in forum iPad General Discussions
    Last Post: 12-28-2010, 12:37 PM
  4. Microsoft Word/office users HELP! I want to edit word on Ipad
    By lanimae in forum iPad General Discussions
    Last Post: 10-21-2010, 10:41 AM
how do you accept word changes on ipad
how do you change a word suggestion
how to change the word of ipad
how to disable word suggestion in ipad
how to make ipad remember words
ipad changes words
ipad search suggestion
ipad search suggestions
ipad word suggestion
ipad word suggestion sometimes
stop ipad changing words
stop ipad from changing words
