Connect Ipad to hard wired internet
This is a discussion on Connect Ipad to hard wired internet within the iPad Help forums, part of the Apple iPad Discussions category; I am going to Europe and the small B&B we are staying in only has hard wired internet. There must be some cord or something ...
Results 1 to 10 of 20
    50423
    May 2011
    North Carolina
    I am going to Europe and the small B&B we are staying in only has hard wired internet. There must be some cord or something that I can get to connect my Ipad to a hard wire internet connection. Wifi is not an option, so please don't tell me how easy it is to set up a Wifi.
    What do I need to get to connect to a hardwire connection. I really don't want to lug my Mac over there.
    Thanks,
    David
    116 times
    15,249
    Quote Originally Posted by dcassels13 View Post
    Thanks,
    David
    I'm sorry to tell you there is no way - you absolutely cannot connect the iPad to a hard-wired Internet connection. OK - that was the bad news.
    But you could take a small wireless router with you, connect that to the hard-wired Internet connection and then use the iPad WiFi. I've done that several times before to get a WiFi Hotspot set up with a wired Internet connection.
    iPad Guru
    30446
    11 times
    3,197
    Taking a wifi router, or access point with you is the only option. The iPad just can't connect to Ethernet directly.
    An Airport Express doesn't take up that much space and is easy to connect.
    I realize you said, don't mention how easy it is to setup wifi, but since it is the only option you have to connect to the Internet...
    50423
    May 2011
    North Carolina
    Thanks for the feedback. I will either take my Mac or take a small Wifi router. With golf clubs and everything else, I was trying to keep things to a minimum.
    Thanks again.
    116 times
    15,249
    A choice between golf clubs and your iPad??!! The golf clubs have to go...
    iPad Guru
    30446
    11 times
    3,197
    There is one more thing to check, while it is certainly possible to take along a wifi router and connect it to setup a wifi network, may the B&B have Internet rules, disallowing the extension of the network. Most hotels don't allow you to create your own wifi, even when paying for the Internet, so you may want to ask the B&B administration beforehand, whether they allow it.
    49895
    Arizona
    16
    Wifi router
    I travel all over Asia, Middle East and India. And I sometimes run into a hotel that is wired only. Actually, quite often. I have a Beldon wifi hotspot that you could put in your pocket - it is that small. And since it is only a single port on the internet connection, the hotels where I have used it, don't have a problem with that connection. Your connection to the 'hotspot' does not create a second IP.
    45545
    Albuquerque
    15
    Has anyone tried this one?
    [ame=http://www.amazon.com/TRENDnet-300Mbps-Wireless-N-Travel-TEW-654TR/dp/B002G1CLS0/ref=sr_1_15?s=pc&ie=UTF8&qid=1305556117&sr=1-15]Amazon.com: TRENDnet 300Mbps Wireless-N Travel Router Kit TEW-654TR (Black): Computer & Accessories[/ame]
    I'm getting ready to go on vacation and the hotel (Marriott) only has wired in room.
    iPad Guru
    30446
    11 times
    3,197
    Quote Originally Posted by Richman1975
    That is just a standard wifi router, so it will work with the iPad. You can use any wifi router/access point, as long as they have one ethernet slot to connect to the wired network.
    If dimension and weight is not an issue, than yes, that one will work. However, if you these two are important, then Apple's Airport Express it the best solution. It is the smallest wifi router available and it has an inbuilt charger, so there are no extra wires, thus reducing both size and weight.
    45545
    Albuquerque
    15
    Quote Originally Posted by DontUnderstandMyIpad View Post
    Thanks!
    I am considering the Airport Express, however it it almost double the price. Size is not a huge issue. I will be probably just using it for just this trip and turning around after I get back and selling it on ebay.
  1. Ipad connect through Internet Sharing
    By Krypty in forum iPad Help
    Last Post: 07-25-2011, 12:04 PM
  2. ipad will not connect to internet
    By csavvides in forum iPad Help
    Last Post: 04-20-2011, 01:36 AM
  3. how to connect ipad 2 wi-fi(only) to the internet when wi-fi isn't available?
    By KarlaMonique in forum iPad General Discussions
    Last Post: 04-07-2011, 08:48 PM
  4. Unable to connect to the Internet with ipad.
    By AndyNZ in forum New Member Introductions - Site Assistance
    Last Post: 01-11-2011, 07:55 PM
  5. iPad connect a Internet-PC via USB cable to surf the Internet?
    By wuzuoshun in forum iPad General Discussions
    Last Post: 11-17-2010, 04:29 PM
connect ipad to wired internet
connect ipad to wired network
connecting ipad to wired internet
hardwire ipad to internet
how to connect ipad to wired internet
ipad 2 wired internet connection
ipad wired connection
ipad wired internet
ipad wired internet connection
wired internet connection for ipad
wired internet for ipad
wired internet ipad
